I have a set of cams from a 1978 Standard that are very different from my set of cams from a 1979 Special. I'm wondering if one set is other than stock.
The cam profiles are radically different. The 78 is on the left and the 79 is on the right. The 78 has a much more gradual ramp on the front and back sides of the lobes, which looks like the valves would have a longer duration around the peak of the lobe. In comparison the 79 has little ramping on either side. It is much more triangular looking near the peak of the lobe.
As you can see here, the marking are very different also. The 78 on top has a flat ground place on the shaft with the identifier stamped on it. The 79 has the identifier in raised characters which are part of the casting. The 78 intake is identified as a X3 and the exhaust is a 9-5. The 79 intake and exhaust are both identified as 3H5.
Here are the lobe diminsions:
Stock spec - Intake 1.449 Exhaust 1.429
78 - Intake 1.447 Exhaust 1.429
79 - Intake 1.448 Exhaust 1.448
So the 78 is within OEM specifications for both cams, but only the intake is in specifications for the 79.
Does anybody recognize these items
Does anybody know how one set would perform over the other in regard to low, mid-range and upper power curves
