partsnmore question
  • AustinPhoenix
    • Mar 2008
    • 112
    • Austin, TX
    partsnmore question
    Does anybody know the difference (If any) between the needle and seat Part#48-1445 and the carb rebuild kit Part#48-1408 other than the gasket? It looks like there are more parts to the rebuild kit, but I can't see what they are.
    Also...stupid question maybe...probably...but what is an XS1100L? I'm looking at brake pads for my front and rear, but some of the kits look different and I'm not sure which I need.
    Thanks guys!
    1980 XS11g Standard - "Ash"
    4 to 2 Exhaust
    K&N Pod Filters
    Fuel Filters
    Inline shut off valves
    Slotted Rotors
    My heart and soul
    Soon to have stainless lines, xs750 FD, lightened rotors, and HID headlight
    1979 Special Project Bike
    Non-gasoline conversion
  • AustinPhoenix
    • Mar 2008
    • 112
    • Austin, TX
    I was just thinking...
    ...maybe I should just remove my pads and look at them to see which one I need.
    I think that makes the most sense.
    Another random question: There's a fuel cap on partsnmore, both of the rubber seals on my gas caps are pretty....rough/cracked/horrible. Does anybody know if those come with them or where I can get the seals at?
    4 to 2 Exhaust
    K&N Pod Filters
    Fuel Filters
    Slotted Rotors
    My heart and soul
      • 7765
      IF you have your STANDARD front forks, the "L" will not work. The pads for the standards are the same, front and rear, for after market. The FACTORY pads have different part numbers, as the rear pads have a little different compound on the pad.
      I have NOT dealt with partsnmore in a while. the carb kit they had DID NOT fit my '79 carbs properly. Georgefix on ebay has ALL the kits, and they work. If you just need the needle and seats with "O" ring, try mikesxs.com. You can order the parts from him, just order two pair of everything and don't let him know it's for an 11.
      • dbeardslee
        • 4385
        • Maineville, OH
        I bought the partsnmore rebuild kits for my 79 standard, but Z1 has a more complete kit. The Z1 kit includes everthing you get with the partsnmore kit plus the adjusting needles with springs, as well as the emulsion tube needles plus the jets for $17. That's a lot more stuff for $5 more. Here's a link
        Z1 Carb Rebuild Kit
        DB
        • oldnortonrider
          • 448
          I have the "screw-in" type float needle seats on my 81 AND my 79; Z1 is not showing that type kit for any of the year models. I think I'll try this "Georgefix" source, next time around. I've had "wrong" kits and pieces from different places.
          JCarltonRiggs
          • dbeardslee
            • 4385
            • Maineville, OH
            OldNorton - Looks like the screw-in seat to me - just doesn't have the little basket on the bottom. Says specifically on the description for '79 F and SF.
            • AustinPhoenix
              • Mar 2008
              • 112
              • Austin, TX
              Z1
              DB
              That rebuild looks like it will work for my Special's carbs, but my standard's carbs are the ones I'm rebuilding currently. Will this kit work? There is another for an SG, but it doesn't look right.
              http://www.z1enterprises.com/detail.aspx?ID=510
              Jason
              4 to 2 Exhaust
              K&N Pod Filters
              Fuel Filters
              Slotted Rotors
              My heart and soul
              • webbcraft2150
                • Sep 2002
                • 1605
                • AUSTIN.TX
                Re: partsnmore question
                [i]Originally posted by AustinPhoenix [/
                Thanks guys! [/B]
                I buy EBC FA34 for front and rear. Dennis Kirk/Chapperal and a host of other on-line dealers sell em. EBC's seem to be a fave here. I have tried pads of lesser price and higher price and always seem to get the "garbage truck" squeals and go back to the EBC brand. Specials take a different pad (thats why they are "special"). My disc prep work consists of a good cleaning with emery cloth and brake cleaner. Don't forget to "run em in" before doing any high speed take downs.
                  • 7765
                  Jason, If you have the "late" '80 carbs with the "O" ring, that should work. The early "80" carbs used the same kit as the '79. Yamaha and Mikuni made changes "mid stream"! Just check the type of needle and seat you need, and order the kit with the correct one.
                  • oldnortonrider
                    • 448
                    Ok > this is the type I use > http://www.z1enterprises.com/detail.aspx?ID=489
                    I just didn't look at all their different "year" models. Pilot screw is different on the different kits, also..........
                    This was what I thought they were showing for all the models >
                    http://www.z1enterprises.com/detail.aspx?ID=510 (they're showing this for 80-81models; I have an 81, but use what they're showing for 78 and 79 models)
                    JCarltonRiggs
                    • dbeardslee
                      • 4385
                      • Maineville, OH
                      Austin - when you go to Z1, just make sure you are browsing under the right bike (does that make sense?). They have the parts divided up by the different models.
                      • AustinPhoenix
                        • Mar 2008
                        • 112
                        • Austin, TX
                        Models and seats...
                        Z1 has some separate categories, but some of the parts still say "Special model only" or something like that. I think it's separated by years only if you look at the product descriptions.
                        There are two sets of rebuild kits for the 80 xs models. They look identical but one says "for special" and it has an extra main jet screw. Do the specials have two mains? Do the carbs change from model to model or year to year? I can definitely see the differences in both of my carbs from the fuel lines running into 4 inlets vs 2, float material (brass vs plastic), slides, needle/seat (little button with screwed in seat vs little wire hook and the seat held down by a bracket and screw) and the jet shapes.
                        If there isn't a difference in the carbs between specials and standards for that year (if they both have the same seats), then I might as well get the extra main for a buck more.
                        Please correct me if I'm wrong...I'm new.
                        4 to 2 Exhaust
                        K&N Pod Filters
                        Fuel Filters
                        Slotted Rotors
                        My heart and soul
                        • dbeardslee
                          • 4385
                          • Maineville, OH
                          My brother has an '80 Standard, and when he first got it the two center carbs had different jets than the two outside carbs. It's got something to do with pollution control or something. My bro jetted all his the same, and it runs fine. Don't take my word though - you can bet somebody else will be along here soon who knows definitively.
                          DB
                          • Axel
                            • May 2007
                            • 869
                            • Renfrew,Ontario
                            XS1100L
                            XS1100G = 80 Standard
                            XS1100SG = 80 Special
                            XS1100LG = 80 Midnight Special
                            "L" indicates Midnight Special in any year that has them
                            XJ1100K
                            Avon rubber
                            MikesXS black coils
                            Iridium plugs w/ 1k caps
                            MikesXS front master
                            Loud Horns (Stebel/Fiamm)
                            Progressive fork springs
                            CIBIE headlight reflector
                            YICS Eliminator
