pod filters instead of airbox
  • rizzo4u2
    • 49
    • hanover,pa.
    removed the air box assembly, now what do you do with the two air lines coming from the carb assembly, and also the breather hose that comes off the motor, thankyou
    mike.s
  • thewiz
    • Oct 2006
    • 1115
    • Wilksboro, NC
    What you don't do
    is plug 'em The ones to the carb rack vent the float bowls so they'll fill and the one to the crankcase vents blow by and other fumes.
    The bike won't run for long with the float bowl vents plugged and the plugging the crankcase vent could blow crankshaft seals.
    Not much help am I?
    80G Mini-bagger
    Past XS11s
      Rizzo,
      Folks have put a "T" fitting on the vent hoses and then a filter on the end of the "T" and secured it up under the gastank so that it is open to air. The big hose, some have just routed it down between the frame/swingarm similar to the battery drain. Others have gotten filters to put on the end to keep moisture, rain, bugs, etc. from getting up there. I've had mine tucked down for 8 years, but I just recently bought a bit of bling from MIkesXS to cap it with a chrome plated filter, now that I'm going to "try" to put a decent paint job on my beast, trying to change it from a "RAT" bike to at least a lizard!
      • HobbyMan
        MeatHead Idiot "GURU"
        • 1801
        • Colleyville, TX
        While on topic, does anyone know the mileage difference when switching to pods?
        Acta Non Verba
        • red bandit
          • 970
          • central michigan
          Pods vs stock air box didn't change my milage any.
          79 SF parts bike.
          • Da-Bubble
            • Jun 2006
            • 353
            • Oklahoma City, OK
            Red,
            Did it change your performance or just make it easier to R&R the Carbs?
            Thanks,
            Scott
            1979 XS11 Special (slightly modified)
            dubbed the "Mad Mosquito"
            MikesXs Pod Filters
            MikesXs 35k Coils
            8mm plug wires
            42.5 Pilots 142.5 Mains
            (Carb tune by GNEPIG Performance)
            Kerker 4-into-1
            Shaved emblems
            Progressive frt springs lowered 1.5"
            Progressive 11.5" rear shocks
            Harley Dyna rear fender chopped
            Custm side mt tag (apparently illegal)
            Custom Dual Headlights
            Lots of time and hard work.
            • powerram50
              • 92
              • portland,oregon
              did you change you from your stock jets?
              81 SH for 300 bucks,work in progress.
              87 dodge d-50,35's,lockers fr&rr,fun.
              87 dodge d-50,35's,open diffs,wifes.
              89 dodge spirit,low 17's 1/4mile w/o turbo.
              • petejw
                • 2269
                • sydney australia
                scott,
                In my case i lost a little torque from idle 2 about 3000 but when she opens up it flys, ive done the usual jetting adj.
                hobbyman
                I havent noticed any change in fuel economy.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
