Is it worth having a spair ignition coil for an XJ11?
You can get a NEW HI Output 3 ohm coil that will work with the XJ's from Mikes XS for $36.00 IIRC, or cheaper, plug and play. So....a used one for that price isn't really much of a bargain!
79SF "The Teacher" . . .basket case! History shows again and again,
