Had a leaky seal in my forks so I just changed the front forks for the spares I had. My front brakes squeaked when I applied them before the swap now they don't which is nice. Now when I apply the front brakes I get a shimmy or a wobble . The tire spins good and there is no rubbing . Any idea's ?
Front end shimy
Front end shimy
BDF Special
Dyno tuned to 98 hp at the rear wheel.Tags: None -
You didn't by chance get any grease or fork oil on one of the rotors did you?
Did you try loosening the tripple tree bolts and retorquing them?
Is the front wheel rotating in the same direction it was?
Just a few ideas James.
PaulPaul
1983 XJ1100 Maxim
1979 XS1100 Standard
1980 XS1100 Special
I'm not a motorcycle mechanic but I play one on the internet.
Hey Paul
Yes I made sure about not getting oil or grease on the anything. I haven't tried to retorquing the triple trees I will give do that in the morning thanks.BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
Hi Ernie
Yes when I spin the wheel I don't see any wobble in the rotors that's why I am a bit stomped on why I get the wobble or shimmy when I brake. The harder I apply the front breaks the more it wobbes ,nothing real serious but enough to concern me. ThanksBDF Special
Warped rotor is also what I think. Block up the front end, spin the tire as fast as you can and slowly squeze the lever. Make a mark on the tire and do this several times. If the mark is at the same spot numerious times then I would say it's warped.
It will also get worse while riding, because the warped rotor gets hotter on the spot were it grabs the most, and expands the metal more at that point.
So you may not find it when it is cool and trying to do it by hand.
Also is there any obvious disimular color on the rotors and is there any rust spots in one area?Flatlander
'81 XS11HComment
Pull those rotors and have em both turned at the same time. If you catch it now you may save yourself some cash in the long run. If they warp beyond turning, you're into more than the cost of a local shop, you're looking at replacing the pair, which can get mucho pricy."Rat Rod"
79 XS1100 Standard
87 VMAX cans
Cheap Japanese Tires
Cobalt Blue Rattle Can Paint
Custom Lighting on a Budget
Perry Center Fire Department
Perry Emergency Ambulance
"If we don't do it, who will?"
Some people have one of those days, I have one of those lives...Comment
I spinned the front wheel many times the rotors are straight as I could want .There is no plusing that comes back to my brake lever. I loosened the trees and retorked it again the shimmy isn't near as bad now. I am going to trry another wheel I have on the weekend and see if there is any difference ,thanks guys.BDF Special
Just a guess...I take it you have the air nipples on your special shocks. Is the air pressure the same for both sides?
With the brakes, did you make sure to put the washers back in the right order when remounting the calipers so they don't bind?
Just thinking of any and all possibilities..Ernie
(Improving with age, the bike that is)Comment
I got thinking about it again
just a thought, when you spun the front wheel and applied the brakes did you feel any movement at the bars. Why I'm asking is that if something to do with the brakes is causing it I would guess that you could feel it this way, otherwise it would have to be suspension related.Ernie
Hey Ernie , I don't feel anything on my handle bars its more like right at the wheel. I think I might try one of those fork braces. I am going to have another look at my brakes again to see if I have reassembled it correctly . Thanks again guys.BDF Special
That might be a good idea ,it's about the only thing I haven't replaced haha! ThanksBDF Special
