Okay...I tore all the carbs apart to clean them prior to taking Soccer4m up on his offer of using his sync tool. I used 4 cans of carb cleaner, went through them 1 at a time, and was super careful to put everything back in its proper place. The idle mixture screws on 2 of the 4 were out 1 1/4 turns, one was out 2 1/2 turns, and one was out 1 1/2 turns. I re-installed all of them 1 1/2 turns out, set the float levels to 23mm (most were 27), replaced 2 broken o-rings on the piece that the float needle goes into, and buttoned them all back up. I did the best bench sync I could, and re-installed all back on the bike. Re-connected fuel lines, set the choke, hit the switch, and fired it up. At first, 1 & 2 exhaust heated right up, but 3 & 4 stayed cool. They finally did fire though, and I clicked the choke back to half way. Choke fully off a few seconds later, still idling high, but I wasn't too concerned because I was expecting that they still needed to be sync'd. I shut everything down, and noticed a nice puddle of gas forming under the bike. Closer examination revealed this.
[IMG]
[/IMG]
Can anyone please tell me what I need to do to correct this? Do I need to get a new needle/seat assembly, or is it something worse? Are my floats set okay at 23mm? Pretty frustrated right now...at least it's only one carb doing it. As always, any help is greatly appreciated.
Mike
P.S Hey Wiz...what part of Vista are you in? I'd like to get your opinion on this if you are close by...PM me and I'll give you my address/phone #.
[IMG]
[/IMG]Can anyone please tell me what I need to do to correct this? Do I need to get a new needle/seat assembly, or is it something worse? Are my floats set okay at 23mm? Pretty frustrated right now...at least it's only one carb doing it. As always, any help is greatly appreciated.
Mike
