xs650 parts on an xs11?
  • Filter
  • xs650 parts on an xs11?
    Hey all,
    I was looking on MikesXS.com for some random parts, and wanted to know if anybody knew if the speedo cable is interchangeable between the two?
    Also, when taking apart my carbs...I was FINALLY able to get one of the screws out to take out the diaphram and found the needle tip was bent slightly. Does anybody know if any of the needles will work with my 80g carbs?
    Thanks gang!
    1980 XS11g Standard - "Ash"
    4 to 2 Exhaust
    K&N Pod Filters
    Fuel Filters
    Inline shut off valves
    Slotted Rotors
    My heart and soul
    Soon to have stainless lines, xs750 FD, lightened rotors, and HID headlight
    1979 Special Project Bike
    Non-gasoline conversion
  • #2
    Too short
    Hi Austin,
    the XS650 speedo cable ain't long enough
    and if you are fitting or already have the XS11Special front forks the XS650 cable bottom end fitting is all wrong too. No sweat, Dennis Kirk carry the XS11 Special speedo cable for ~ $16.
    The appropriate year XS650 carb needle should fit. Apart from some body casting differences it looks to be the same carb.
    BTW, LED brakes?????????? Must be retardation by photon pressure, right?
    • #3
      From MikesXS.com
      Jet Needle - 5HX12 - Fits:XS650G/H/SH/SJ/SK/SL (1980-84) stock Mikuni BS34
      CV Carbs.
      Yamaha Manual shows the needle jet to be 5lZ7 for the G and a 5GL16 for the SG. Think would try getting the right one from sudco or motorcyclecarbs.
      Was going to post a link from "favorites" but just checked and there not working
      mro
      • #4
        Er?
        Ok...So Fred...I can get the speedo cable from your source. Great! The part with the threads was broken on mine so there's no way to re-attach it.
        As for the needle...go to Sudko then? The other place's site is down. And for sure, the one on MikesXS won't work? I'm trying to save money on shipping and time for the handling of it all.
        I wonder how it got bent to begin with...
        Thanks for all the help you all!
        4 to 2 Exhaust
        K&N Pod Filters
        Fuel Filters
        Slotted Rotors
        My heart and soul
