Well, folks asked, and I promised. I have had my AEM kit in for a couple weeks now and am loving it. It gives me info while I ride on what areas of my throttle curve are off. The kit can be had for just over $200 on ebay. NGK makes a cheaper kit, but after doing a little research and reading some bad things, I decided to fork out the extra 40-50 for this kit. There isn't much to say about the install. It couldn't be easier, really. The gauge houses controller unit. Kit comes with a Bosch Wideband sensor. I took my header down to a local muffler shop and they welded in the threads (included in the kit). After that, all you do is connect the sensor to the controller with the included harness/plugs, provide (+) and (-) power, and mount the gauge somewhere. Currently, mine is in a very temporary position held with a zip-tie. The great part, is that when I finally go Megasquirt, this unit is plug and play. I could even rig it to a lap top to do data logging with just a serial wire and a program Window already has
