Electrical Diag Quests?
  • jjwaller
    • 242
    • Gautier, MS
    Hi Folks:
    I am an Industrial Instrument and control Technician so I know just a little bit about schematics and electrical components.
    Have a 78 E and trying to sort out the last fine points of the Elect. system.
    Question: Headlight Relay? Can't Physically find it or in Yamaha parts diagrams. Possibly known as dimmer Relay (In Clymers) I don't have one. Second, I have a right hand control that has Light on/off switch that doesn't do anything.
    Traced out the cable from the RHC to the plug under the tank and found that the blue and white wires are switched by the RHC light switch. The blue wire does not leave the downstream plug. Anybody have a clue? Do I have a europeon replacement part or was this standard in 78? Does the XS11 CD ROM available have all the real schematics
    for all the early bikes?
    Last, I do have a Windjammer on the front. So naturally the headlight goes through the fairing. There is no relay behind the fairing.
    Thanks
    John
    John
    '81 CB900C ( 10 Speed)
    '78 CB750F ( The F)
    '76 CB400F ( The Elf)
    New '82 Honda MB5 Ring Ding
    Then: '76 CB550K
    '78 CB750F
    '84 VF1100S
    And still Looking!
  • randy
    • Dec 2003
    • 4521
    John,
    The headlight realy should be under the tank, between the frame rails directly behind the steering stem. If you don't have one, and you headlight works, maybe the PO rigged it somehow? You should find a 4-pin plug there. If the plug is there, contact Andreas here he may have a relay for you.
    As for the RHC that does sound like a European part, the US models did not come with a light switch. There is a remote chance that you have a European model, but the serial number on them would begin with 2H9, check the tag on the steering stem for your serial #.
    • mro
      • 4276
      • Hayward, California
      RHC
      Could have been an after market part too.
      MikesXS sells em. Found one on a 79F I picked up awhile ago.
      mro
      • newc4
        • 643
        • Vienna VA
        My 78E has the light switch on the RHC, it is standard equipment. It allows you to turn off the headlight when the engine isn't running. For instance, if you have a weak battery, you can turn off the headlight while starting. For a while I could turn off the headlight while my bike was running but after some poking around under the gas tank to replace my regulator it operates as advertised.
        I believe the relay senses current from the alternator activating the circuit.
        Darrell
        Darrell
        78E
        80G project
        06FJR
        • D. P. Larmee
          • May 2003
          • 224
          • Evanston, IL
          The yamaha shop manual shows the 78 wiring diagram as having a "lights" switch that when on links Blue, Red/Yellow, Black/Blue. It also shows the relay. It sort of looks like the switch could be used to turn the headlight on while the bike was not running, but did not turn it off if the relay was tripped.
          1980 XS 1100 Standard
          1980 XS 1100 Special
          1982 XJ 1100
          1972 Honda CB 350
          • CarolynS
            • 369
            • Massachusetts
            Windjammer
            If you go onto the Vetter site, they have the wiring diagram for the Windjammer. Don't know if that helps.....
            80 XS1100G w/ Windjammer-the Witch
            79 XS1100F
            "Look Ma! No hands!...."
            • planedick
              • Mar 2005
              • 2068
              • Yorba Linda, California
              Switch
              I have a 78E and it has the switch on the right which allows me to turn the headlight on when the engine isn't running. The relay is set (turned on) by current from one leg of the alternator so if the engine is running the headlight is on. There is also another relay in the circute which will turn on the other element of the headlight if on burns out, and lights a light on the panel to let you know what happened. It's called a auxilary relay I think.
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              Custom security system
              Stainless braid brake lines
              • jjwaller
                • 242
                • Gautier, MS
                Originally posted by randy
                John,
                Thanks Randy, found it finally after looking closer. Now I have someplace to start tracing from.
                John
                '78 CB750F ( The F)
                Then: '76 CB550K
                '78 CB750F
                '84 VF1100S
                And still Looking!
                • jjwaller
                  • 242
                  • Gautier, MS
                  Thanks DP:
                  Guess I'm finally going to have to spring for the shop manual.
                  John
                  John
                  '78 CB750F ( The F)
                  Then: '76 CB550K
                  '78 CB750F
                  '84 VF1100S
                  And still Looking!
