jetting
  • GARTHXS
    • 1631
    • Seattle
    jetting
    I am installing a bassani 4/1 exhaust what size dyna jet kit should I get
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    NONE!!!!!
    Just buy 4 mains for the mikuni. It will be MUCH easier to tune, and your bike WILL run better. Do a search on jetting, or go to the MAIN page, and look at the tech tips under engine. There is a chart that can help you choose the proper jets. If it's just the Bassani pipes, you may not have to change ANY jets, depending on the muffler and back pressure.
    • GARTHXS
      • 1631
      • Seattle
      I have individual filter pods as well
      91 kwaka kz1000p
      Stock
        Here is the link to the "jet" guide.
        Use this as a start point and then just test. I think you will only need to go up 2 jets, but if you want all the power, and damn the gas, go up 3 with one size up on the pilot jet.
        • GARTHXS
          • 1631
          • Seattle
          what size
          So what size would that be ,I cant really figure out all those equations
          91 kwaka kz1000p
          Stock
          • 81xsproject
            • 3185
            • Fortuna, CA
            The jet sizes are by 2.5 increments. So, if I remember right the stock pilot is 45 and the main is 137.5. So, 2 sizes up on the mains is a 142.5 and 3 is a 145. 1 size up on the pilots is a 47.5. Get genuine mikuni jets.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • GARTHXS
              • 1631
              • Seattle
              thanks
              As you may have noticed I am not a mechanic but I have basic skills , so if It is in plain english and not tech speak I may be able to figure it out
              91 kwaka kz1000p
              Stock
                I just ordered some jets for my project from mikesxs.com. Good prices, just order two of everything and the setup should go smooth. I also am replacing my coils on daily ride. They still work, but have 100K on them, so it's a matter of the coil wires. I'm out of trimming room for the plug caps, and the two "HP" coils from mikes are only $64.00!!
                DO READ THE JETS YOU PULL OUT!! I would make sure you have one size either way, so you can do as you want or need.
