Greetings all.
I've decided to start working on the SF again and will probably have a few questions for you good people.
So let's start tonight.
The bike has been sitting in my garage since at least 1991 and the other day I decided to pull the spark plugs. I was very concerned that the rings or valves or something other may be stuck due to the engine being stationary for so many years. So I pour in about 1/2 oz of Marvel Mystery Oil into each cylinder, mount the kick start lever and try turning the engine over by hand - NO PROBLEMO. I then kick it over a few more times with my leg and everything feels to be spinning over freely.
So my question is this - what is the best way to pump up the oiling system. First of all I am going to do an oil change, but then what method would be the best? Repeatedly turn it over with the kick starter? Hook up a battery and use the starter motor (not sure if I like this idea because I am afraid that there would be too many high speed revolutions with no oil in the top end)? What about spinning the engine over slowly by using the crankshaft bolt and a light touch with an air ratchet? Or is there a way that I can prime the oil pump and pressurize the oil system without turning the engine over? I am guessing that there probably is - but how easy of a procedure is it?
Anyway, let's hear what you guys & gals think.
Thanks in advance,
Scott
Thanks in advance,
Scott
I think they are in a box in the basement somewhere.
