Heat shrink on the carb holders
  • SanDiegoMike
    • Oct 2005
    • 192
    • Near the beach!
    Any of you ever used it? PO slathered mine w/a LOT of RTV...manged to get it all over the fins as well. Looks like...well...you know. I'm wondering if covering them with heat shrink would be an option, or would the heat from the engine cause problems for it. I'm trying to find a way to make it look better w/o spending $100.00 for new holders.
    Hi...my name is Mike, and I'm a lane-splitter.
    '80 XS1100SG (mine)
    '87 CMX450C Rebel (daughter's first bike)
  • John
    • 5117
    Mike
    Just clean all the rtv off real well, and wrap them with electrical tape. It looks good from a few feet away, and stays stuck. I did that with Wildkat's bike, and it's held up well.
      • 8863
      coating
      I've heard of people using this Plasti-Dip coating on those carb boots. Napa auto carries it, but i'm not sure of how much heat it can handle. HTH.
      • JACKHAMMER01
        • 115
        • Myrtle Beach SC
        Plast-Dip works pretty well, and will withstand the heat in that area. But PartsNMore sells the carb holders, new, for only $90.
        Try that link.
        Jim Horton
        Myrtle Beach SC 29588
        843-274-5045
          • 7794
          Mike,
          IF you get the LARGE heat shrink, it should work. It will loose about 30% in size, so choose a size that will just be snug when you are done. You can even change the color, if you want!!
            I just posted a reply to another thread about this very topic.
            Here's an alternative to Electrical Tape!
            Here's the rubber tape from Lowes:
            Glasgow
            1" x 16' Roll Magic Wrap Plumbing Repair Tape
            Item #: 26668 Model: 86001
            Emergency repair kit on a roll
            Works on dirty or wet surfaces, adheres to itself
            Repairs cracks, splits, tears
            Ideal for plumbing, automotive, electrical repairs
            Withstands up to 200 psi
            Lasts indefinitely
            Works in temperatures from 0 degrees to 200 degrees F
            • Yamaniac
              • Jul 2005
              • 262
              • Stilwell, KS
              where in the world do you get heat shrink that big???? Biggest I have seen it is about 1/2" diameter before it gets heat gun.
              Thanks
              Theron
              Yamaniac
              '79 xs11 sf - WidowMaker, 750 final drive
              '80 xs1100 sg- ENEMY#1 parts bike no title(free)
              '79 f- frame and swingarm (and title)
              '82 yz 490- needs a cylinder, head, & new piston, etc. Got one for sale?
              '88 Honda cbr600- Running, finally! Training bike for swmbo, maybe a stunt bike for me eventually.
              • jjwaller
                • Oct 2005
                • 242
                • Gautier, MS
                Try an electrical supply. Used to terminate big cables. That is an idea , you can get 500 or 750 MCM heat shrink with environmental sealant on the inside. Seals terminations from the environment.
                Have to look into that. Temp is the consideration. High voltage stuff should handle it... but
                Anybody have any idea what the temp is running on the backside of the engine on the carb boots?
                John
                Now: '78 XS1100E 750 FD Mod (Big Dog)
                '81 CB900C ( 10 Speed)
                '78 CB750F ( The F)
                '76 CB400F ( The Elf)
                New '82 Honda MB5 Ring Ding
                Then: '76 CB550K
                '78 CB750F
                '84 VF1100S
                And still Looking!
                • Do Lee
                  • Feb 2003
                  • 255
                  • Victoria, Texas
                  Here some info from Buyheatshrink.com
                  2 to 1 Standard Wall Polyolefin Heat Shrink Tubing
                  Features:
                  2:1 Shrink Ratio (shrinks to ½ its original diameter)
                  Meets requirements of SAE AMS-DTL-23053/5 (formerly MIL-I-23053/5, MIL-DTL-23053/5), Classes 1, 2 (Clear), and 3
                  UL 224 VW-1 and CSA OFT recognized
                  Maximum Continuous use temperature 135°C
                  12 standard colors: Black, Clear, Red, White, Blue, Yellow, Brown, Gray, Orange, Green, Violet and Yellow/Green
                  Shrink Temperature of 120°C and operating temperature of -55°C to + 135°C
                  Crosses to : Sumitomo B2, Raychem RNF-100, Alpha FIT-221, 3M FP301 heat shrink, Canusa CPX-100, LG GSHS-1635F
                  Typical applications include: Insulation, Wire Identification, Wire Bundling, Mechanical Protection, Color Coding, Lightweight Harnessing, Physical/Electrical Protection of Components, Strain Relief, and Solder Insulation.
                  23053/5- 114, Nom ID 4", Flat Width 6-516", ID after shrinking 2.00" Price 1' $6.75
                  Black Clear Orange Red White Blue
                  Do'Lee
                  XS1100SF "Green Hornet"
                  (1) XS1100LG "Midnight Dream" Restoration has begun.
                  (2) XS1100LG "Midnight Madness" Waiting to be next
                  (5) multi partsters for bobber "Ruby Red II" On the list.
                  SR500H "Silver Streak"
                  • SanDiegoMike
                    • Oct 2005
                    • 192
                    • Near the beach!
                    Thanks John!
                    Thanks for all the input from everyone. I like all of the heat-shrink info.
                    I couldn't take looking at the carb holders one more day, so I went with Johns suggestion. If it's good enough for Wildkat's bike, it's good enough for me!
                    '80 XS1100SG (mine)
                    • John
                      • 5117
                      Thanks
                      How does it look?
                      • SanDiegoMike
                        • Oct 2005
                        • 192
                        • Near the beach!
                        So far so good...
                        Looks a whole lot better than before! PO slathered so much RTV on them (WITHOUT removing them from the engine ) that the gap between the oil line and the #3 manifold was completely filled in!! I also noticed (and didn't make the connection until the next day) that there were NO gaskets between the manifolds and the head. Please don't crucify me too much for asking this, but...there should be gaskets...right
                        '80 XS1100SG (mine)
                          • 7794
                          NO GASKETS from the factory. The original had an "O" ring that was part of the rubber cast around the mount. They CAN leak, so a check for leaks would be a good thing.
                          • John
                            • 5117
                            Mike
                            If you should find a leak where the boot is attached to the head, and find the need for a gasket, you can use a thermostat housing gasket from a 2.3 liter engine in an older Ranger or a Mustang. The bolt pattern is correct, and with very little trimming it will work well.
