Final drive filler cap wont budge
    • 6763
    Randy and I are going to do surgery on MadMax tomorrow...in doing the pre-surgical prep..one of the things to do is drain the middle drive and final drive fluids.With a 6mm allen tool the filler cap on the final drive wont budge.So I tried to heat the bolt with a torch using Mapp gas...Ionly keptt the heat on it for a long minute...it wasn't enough..net result...no change...SO my question is...How long should I heat up the bolt before trying to loosen it?Any other method more effective...???
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
  • red bandit
    • 970
    • central michigan
    You can use a hammer and chisel to try to turn it will someone else uses the allen wrench. Randy nows how.
    79 SF parts bike.
    • randy
      • Dec 2003
      • 4521
      Ben, if you're using heat, don't heat the bolt, that will make it tighter as the heat expands the bolt. let everything cool, then use heat on the HOUSING around the bolt. When you're ready to wrench it, tap the bolt first with a small hammer. This method always work for me.
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        And when you put it back in use a little bit of anti seize on the threads and torque it only to the manual specs.
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
          And use a new crush washer too. A gently used washer from a sparkplug will work, as will a nylon washer if you can find one that size.
          • mro
            • 4276
            • Hayward, California
            What they said.
            Aluminum expands faster with less heat than steel.
            One minute should be enough...altho
            guy brought his XS to my shop because he could not get the filler plug out. First tried getting it out with an impact goody, then with propane tourch and impact. Wound up using hammer/chisel
            mro
            • mason79
              • Mar 2006
              • 1359
              • los angeles, ca
              rode for a while to heat up the housing then try again worked for me. then use antisieze and don't over tighten
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
                • 6763
                Thanks everyone for their input... I appreciate the value of experience...I will be heading back out to the garage now...
                  • 6763
                  Dumb$### Award
                  Went out to heat up the housing around the final drive filler bolt and I followed previously given advice abt how to remove the bolt but in the process I managed to strip the head with the allen tool ...God I HATE allen heads...so not sure what to do in this case.I think I will wait for reinforcements...just goes do show you who should get the dumbsh## award for the month
                  • wa407mpp
                    • Jul 2007
                    • 717
                    Impact driver.
                    Am I the only one on this site who owns an impact driver, they were invented for jobs like this, if you don't have one, buy one, it will save you a lot of work, frustration and striped parts.
                    Fastmover
                    lion". SHL
                    78 XS1100e
                    • Flatlander
                      • 288
                      • Michigan, Thumb
                      I've found that to work also, Randy.
                      And with two differenrt metals, I've also taken a ice cube to the bolt for a couple of seconds. This has helped I think.?.
                      What, dosen't every one have some cold ones on ice in the garage?
                      Flatlander
                      '81 XS11H
                      • mason79
                        • Mar 2006
                        • 1359
                        • los angeles, ca
                        Re: Impact driver.
                        good idea never thought of that, but i never said i was a good mechanic.
                        i may buy for for my stuck middle drive filler
                        History
                        85 Yamaha FJ 1100
                        79 yamaha xs1100f
                        03 honda cbr 600 f4
                        91 yamaha fzr 600
                        84 yamaha fj 1100
                        82 yamaha seca 750
                        87 yamaha fazer
                        86 yamaha maxim x
                        82 yamaha vision
                        78 yamaha rd 400
                        • xschop
                          • Feb 2006
                          • 1794
                          • oklahoma city
                          dremel
                          dremel a large slot and smack it CCW with a chisel. Been there.
                          MDRNF
                          79F.....Not Stock
                          • 79XS11F
                            • 3563
                            Once you get that slot made in the cap heat the case up REAL good and apply some penetrating oil... let it cool and repeat. Then heat her up again and go at it with the cold chisel.
                            Rob
                            1978 XS500E
                            1981 Suzuki GS1100
                            • ross
                              • Dec 2006
                              • 542
                              • see signature...
                              madmax-im.....just a thought....if ya wanna spot freeze a bolt.....just go 2 the office supply store and get a can of air duster 4 your computer keyboard.....heat the hub area......then turn the air duster can upside down, use the spray straw, and it should spot freeze the head of the bolt.....spray until the bolt frost up.......(please use safety glasses as this is not something you want in your eyes!!!)......not sure if it will work, but will greatly improve the expansion differences between the hub and the bolt.....that and an impact driver should do it...if not, if u have a harbor freight in the area, get a cut-off wheel, cut the slot, and use the chisel with great care...as a last resort, drill it out, cut slots in the drilled out hole without touching the threads and using a chisel fold the walls of the plug into the hole......ross
                              rebel devil
                              1979 xs 1100f standard
                              authenic historical vehicle
                              42°36'23.52"N, 82°52'44.78"W
                              "I'M IN MY HAPPY PLACE"
                              "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
                              "if you don't wrench on it, get behind me satan!"
                              '96 venture cct.....installed!
                              stainless, braided, pvc coated brake lines
                              i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
