the external "octy"....
hey there folks...the latest news.....obkaybe....got the goodies and hooked her up.....mind you i didn't get to start this project until 9 pm and i had to ride her 2 work at 7am the next morning....no pressure....anywho, this setup is the schiznig.....works very well....as soon as i had it hooked up, i saw the error of my ways....all 4 carbs were off.....bread tie idea is no good....i made the setup to work so that all the the controls were mounted to the handlebars....
also while i was draining the gas tank, i went to open up the cap to get her 2 drain better....noticed that it was quite a noticable difference with the cap open...so, just 2 b sure, i tore the cap apart and made sure the vent was clear...i'm gonna replace the little spongy thing as soon as i can....photos just 2 show what it looks like torn apart....
well, i got the s*cker dialed in as best as i could.....considering i only had 2 hours to do it....the nice thing about this is that no matter how hard you blip the throttle, there is no harm, no foul....it's amazing just how touchy these carbs are....1/4 turn here and there and suddenly things start sounding really good.....sad to say with little time, i really didn't get picky with being exact....(it probably didn't help having a couple holy waters (bud dry) while i was doing the project)....got her close and threw a new plug in #1....ran her 2 work and back the next day...ran a lot better, but still had some coughs and burps...#1 plug is still running black....got her back home and hooked her back up again....noticed that the settings were off a bit...dialed her in again and got all 4 carbs set at 10 cm Hg.....sounds great....
gonna find out 2day as we are riding to meet renegade_xs11g out just past ann arbor (70 miles one way)....hopefully 2 get my new seat...also, while i was at the "zone", i purchased a laser thermometer....this is really a must have for checking pipes and cylinders....did notice that one side of the engine is running cooler than the other side, but right now i just want 2 get #1 fixed and firing correctly....also, renegade_xs11g mentioned to check the enricher valve and make sure it was clean and seating properly...pulled it apart and stretched the spring a little to make it seat better...seemed to idle a little better, so we will see.... i shall leave you with a final picture of the "external octy"...
thanx 2 all for the advice and will let u know how she runs later on this weekend.....ross
Then you tried running it, found #1 plug blackened vs. the other 3 and have gone into much efforts with synching, electrical diagnostics, etc.!
, your #2 main jet looks rather gummed up?? Also, you stated removing the resetting the #1 Pilot SCREW, but what about the pilot jets under those little screws next to the main jets??? Did you actually remove ALL of them, soak the pilot JETS, squirt cleaner thru the pilot jet tower to ensure flow thru the circuit, first seeing it come out of the removed pilot screw hole, and then with the screw in place, coming out thru the 3 small orifices in the upper part of the carb throat, the ones used to verify the presynch technique??
