whats better???
  • GARTHXS
    • 1631
    • Seattle
    whats better???
    What do you think is better, stock forks off a 78 standard, or air forks off 80 standard
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    Stock with progressive fork springs. I have about 60K miles since I put the progressive springs in. Rides and handles great!!
    • AlanB
      • Oct 2006
      • 705
      • Scotland
      Hi Garth,
      I am with DiverRay about the springs, but I don't think you need to change the forks?
      I played around with the air when I got my bike, then let it all out and fitted progressives........ BIG improvement.
      AlanB
      If it ain't broke, modify it!
      • GARTHXS
        • 1631
        • Seattle
        whats better
        The reason IM asking is because I have a complete parts bike a 80 xs1100 standard
        with air fork on it and I wanted to see if it was worth the trouble of switching them on to my 78
        91 kwaka kz1000p
        Stock
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          If you want to try the set up with air just change out the fork caps. They should be interchangeable. Just don't remove both the caps at the same time or the bike will NOSE DIVE off the main stand. Do them one leg at a time.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
          • Jerry
            XS & TRUE XJ GURU
            • 3023
            • Elma, IA.
            FWIW....
            Most of those who have upgraded their front forks with progressive (small "p") springs have given up using air pressure to adjust the front forks. Progressive is one brand, most common, but there are a few other ones out there. Seems to me some years of the XS had a "heavy duty' spring option which was, in fact, a set of progressive-wound springs.
            Upgrade used to cost about $100.00 for springs and new fork oil, such an upgrade will make your bike handle better. Those OEM front springs are now up to 30 years old and have lost something over the years. I would go with an upgrade instead of swapping parts and pieces if you have the budget for it. Also add a fork brace (FB) if you don't already have one.
            Jerry Fields
            '82 XJ 'Sojourn'
            '06 Concours
            My Galleries Page.
            My Blog Page.
