http://www.imagedump.com/index.cgi?pick=get&tp=530658
http://www.imagedump.com/index.cgi?pick=get&tp=530659
Please note I have recently replace the fork seals, added progressive springs, and TKAT Fork Brace. I loosened the front and retightened at least four times now trying to fix it. The left side rotor is not centered. There doesnt seem to be an adjustment for it. Is it suppose to be like this?
I have two problems at this time.
@ 70mph I start to feel this rythmic vibration DA DA DA DA (pause) Da Da Da Da (pause)... It gets faster with more speed. Changed the rear shocks to 4 on the dial. It was at two. The rythmic vibration improved, but not totally eliminated. Im wondering if this is a rear shock problem or front tire. Rear shocks are orignal. It has new metzler on the front and rear. When I spnin the front tire the rotors look true. But the tire seems to wobble a little. The tire beead looks to be in the right place.
When using front brake at 20mph feels smooth. When using it at 50mph the front vibrates. Im thinking this is from contaminated brake pads. When I got the bike. Shock oil was leaking all over the engine and brakes/forks. Me being a cheap ---. I just cleaned the pads and reinstalled them.
Am I on the right track?
