Valve Shims
  • trapper_492001
    • 88
    • Cambridge Mn
    Valve Shims
    Does anyone know a good source for a compleat set of valve shims. I am tired of waiting to get the shims I need to adjust the valves.
    Trapper
    81 SH (SHotgun Special)
    110 mains
    idle jets 2.5 turns
    floats at 24mm
    You live, You learn, then Die and Forget it all
    I just checked Bikebandit... How aptly named! They have all you want at $14.06 EACH!!!
    Most bike shops will have these shims. Yamaha isn't the only bike that used them. Just make sure to measure them first since there is a 29.5mm shim and you can't tell by looking at it, but it won't fit in the shim bucket.
    Ebay has full sets come on every once in a while, but they go pretty high.
    • randy
      • Dec 2003
      • 4521
      trapper_492001;
      Have you PM'd John? He has a 'library' of shims, you can swap your spares for the ones you need.
