Fork service
  • newmaac
    • Dec 2002
    • 369
    • San Jose, CA
    Fork service
    I am about to do some work on my 1980 Special front end.
    I purchased a set of fork seals on e-bay. In addittion to the fliud seals, are there replacable parts that I should address while I am "in there"?
    Is there a way to identify the springs? I was thinking about buying the Progressive springs, but don't know for certain that this has not already been done by a PO.
    TIA
    Mike
    Mike
    1980 SG "Angus"
  • Wayne
    • 824
    • Shenandoah, Texas
    On the progressive question...
    You can tell if you have them when you pull them out of the tube.
    If the spring tension (distance between each coil) is the same all the was up, then you prolly have an original spring.
    If the spring tension gets small as you go then you have a progressive spring.
    Note in pict...
    See how the tension gets tighter near the end of the spring. That is progressive.
    Note about changing to progs. I did this mod about a year ago. I highly recommend it. My bike is a standard full tourer and it really made a difference. Now I just need progs on the rear!!!
    Also in mods for your front end, make sure and find yourself a fork brace if you don't have one now. It also helps handling bunches.
    Progressive Suspension web site
    Tkat's fork brace, I recommend this one.
    Ride Safe
    [b][size=4][font=times][color=#BD0062]Wayne[/color][/font][/size][/b]
    [b][size=4][font=times][color=#095de5]TeXSive forever[/color][/font][/size][/b]
    The best alarm clock is sunshine on chrome.
