Kick Starter?
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    Kick Starter?
    Hi,
    Is it worth it to install the kick starter gears and setup on my '80G in case the battery ever goes dead? There's one for sale on cheapbay.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
  • randy
    • Dec 2003
    • 4521
    If your battery is truly dead, it won't have enough juice to light the TCI anyway, so the kicker may not help. The kicker will work if the battery charge is marginal. I think better than the kicker, if you find a nice steep downhill, first gear and pop the clutch to start it.
    • erithanis
      • Dec 2007
      • 89
      • Sunnyvale, CA 94089
      It doesn't even need to be that steep. I've successfully started my 79SF by getting going at a fast walk, hopping on and dropping it into gear.
      Looking for an XS
      79 XS1100SF (RIP)
      - stock standard headers(stupid PO), slip-on after-market mufflers.
      - after-market rear shocks (PO installed)
      - no airbox, POD filters
      Misery remembered is ADVENTURE!
      • Dennyz
        • 1151
        • Olympia, Washington
        In all the years of running XSs, I have only had to resort to the kick starter once and it was marginally successful. I had to ride with the head light off to make it home. A new battery is probably cheaper that the ticket for no head light.
        If the battery is too dead to start the bike, but the kick starter will fire it up, as soon as the head light comes on, the engine will die. To keep it running while putting the headlight fuse back in is an awkward situation. The motor has to be doing over 2k to charge the battery, run the bike and power the light. And that is if everything is working correctly (which means you would probably never need to kick start).
        Save your $$ for a new battery (IMHO).
        DZ
        Vyger, 'F'
        "The Special", 'SF'
        '08 FJR1300
        • Cobia
          • Jul 2007
          • 1587
          Kick starter
          Thanks guys, I was just wondering if the alternator had enough juice to keep the bike running even with a dead battery. I saw an assembly on cheapBay and wondered if it would be useful.
          Gracias Amigos!!
          Kerker 4 - 1
          850 Rear End Mod
          Automatic CCT
          '82 XJ1100 (Sold)
          • Paintman
            • Mar 2008
            • 312
            • rapid City SD
            Kick starters
            After spending many yrs jumping on my old Norton 850 and my 750 Bonnie LOL id rather push something home then get launched over the bars.
            John
            79 XS1100SF 750 FD,Galfer Brake lines,ebc brake pads,Cross Drilled Rotors,TKat fork brace,bead blasted wheels repainted and polished
            80 XS1100 S Project gonna be a hot rod
            06 CBR1000RR sold!!!!!
            2000 Concours
            84 Kawi KLR600
            79 Yam XT500 Ouch it kicks back
            79 XR250
            Why is it that the smallest part can fly to the farthest part of the shop?
            John
            • xsilerating
              • Dec 2006
              • 430
              • Eastern Ontario, Canada
              Agree! I've started mine quite a few times on a very slight decline - while sitting on it - and taking 3 - 4 steps and popping the clutch. Worked every time.
              (Had to do this until I figured out that my aux. lights were sucking the juice out of the battery. )
              1980 XS11 LG (Diablo)
              1980 XS11 G (Bagger)
              1978 XS11 G (White Knight)
              1978 XS11 G (Skeleton)
              2016 SS (S.S. Flyer)
              • desert1
                • 750
                • Grand Desert, Nova Scotia, Can.
                850 yAMAHA
                I put a folding kickstart on my 78xs its off an 850 Yamaha, $15. on ebay, works great and I do use it, folds up neatly out of the way, only minor alteration on the kick shaft some dremmiling to allow for the pass thru bolt on the kicker.....
                HEY "PAINTMAN" I hear yah about launching over your bike: long time ago owned an AJS 650 twin, when that kickstart would slap back at the sole of your foot, many expletives would follow, still remember the pain...
                You still need some power in the system to fire the engines but I just wanted a kickstart cause every bike I rode in the 60s and 70s had one and now I do.....
                Bruce
                78xs1100
                Bruce Doucette
                Phone #1 902 827 3217
                • AlanB
                  • Oct 2006
                  • 705
                  • Scotland
                  Hi Guys,
                  Fours are a LOT easier to kick over than twins!
                  The XSs electronic ignition should make sure that the timing is always correct, so the "kick-back" and the launch over the 'bars which the old Brits were famous for is a thing of the past.
                  I really don't know why, but there is something cool about seeing a big bike kicked into life........
                  AlanB
                  If it ain't broke, modify it!
                  • jurgenkoppen
                    • Jul 2007
                    • 97
                    • Powell River, BC Canada
                    I agree, to kick it into life is cool
                    Especially when she goes on the first kick.
                    I got a 750 foldable kicker from Ebay, and will install it in my 79 engine in 80 frame red unit asap, just for kicks....
                    I have been futzing with my projects and just got my first "home build" bike road ready.
                    Had gotten it all in bits and put it together, painted it, and with Andreas' and Ebay parts and your help got the show on the road today and now applied for collector plates.
                    Anyway, wondering if anybody might have the little anti rattle clips for the 80SG, which sit in the fork's indentations and keep the brake pads from being noisy.
                    Also missing in action on my other project is the spacer, which keeps the front wheel bearings apart, and one muffler hanger rubber grommet.
                    If you have, could you let me know, I never seen those things on Ebay.
                    Thanks Jurgen
                    80 1100SG with 79 engine
                    79 1100F being restored
                    78 xs650 runabout (mpg, eh?)
                    Irreverence is the champion of liberty and its only sure defense
                    • erithanis
                      • Dec 2007
                      • 89
                      that bike is beautiful
                      Looking for an XS
                      79 XS1100SF (RIP)
                      • egsols
                        • Jan 2006
                        • 1090
                        • Barrie, Ontario, Canada
                        I have the original that came with the 79 and use it occasionally for fun. It starts up no problem and I was surprised how easy it was to kick. I was used to kicking old singles and twins but the worst to kick was an old HD sportster.
                        I guess the fascination in having a kick start is like the old wall phone I have in my garage that you actually have to "dial"!
                        Ernie
                        • RUSH
                          • Feb 2005
                          • 214
                          • Lake Stevens, WA
                          Ive used the emergency kick start on my bike many times. It works well and I have often wished I could mount one permanently. You do need a battery with some charge left in it to use the kick starter. The occasions I used it were with an old battery that would not hold a full charge, but could still run the lights.
                          First bike was an: 1978 XS1100
                          Second bike is an FJR1300.
                          Now I'm restoring a '79 XS1100.
                          • ross
                            • Dec 2006
                            • 542
                            • see signature...
                            hey there desert1....any chance you remember what 850 that kickstarter came off of.....i got the stock one, but if i could find one that folds...i just might have 2 make that the starter of choice some times...thanx in advance....
                            p.s. if u got fotos of yours that would be cool also...just 2 get an idea...ross
                            rebel devil
                            1979 xs 1100f standard
                            authenic historical vehicle
                            42°36'23.52"N, 82°52'44.78"W
                            "I'M IN MY HAPPY PLACE"
                            "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
                            "if you don't wrench on it, get behind me satan!"
                            '96 venture cct.....installed!
                            stainless, braided, pvc coated brake lines
                            i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
                            • Cobia
                              • Jul 2007
                              • 1587
                              Kick start it to life...
                              Since Yamaha did away with the gearing, as well as the lever, in 1980...... my question is can you retrofit the kick start gears/shaft/etc. from an older one if you can find it? I saw one recently on ebay and that's what got the string started.
                              I agree with all of you that kick starting the bike is way cool, especially since the fours are well manered and won't buck you over the handle bars.
                              Kerker 4 - 1
                              850 Rear End Mod
                              Automatic CCT
                              '82 XJ1100 (Sold)
