Ballast resistor...
  • SanDiegoMike
    • 192
    • Near the beach!
    Ballast resistor...
    Where is it located on the SG?
    Hi...my name is Mike, and I'm a lane-splitter.
    '80 XS1100SG (mine)
    '87 CMX450C Rebel (daughter's first bike)
    I don't think the "G" model has a ballast resistor. The resistors are on the "E" and "F" models, "G" and later have coils with a higher resistance, and don't need them.
    IF you do have one, it will be under the left side of the fuel tank, with two red/white wires going to it. Mine is mounted low, so it has to be pulled in order to remove the valve cover.
    • eroellig
      • 229
      • Arkansas
      Hmmmm...... My SG had one. I removed it when I changed to the MikesXS coils.
      Eric
      Eric Roellig
      1980 SG w Windjammer V & KG hard bags
      **Very first bike**
      Current condition: Running!!! Lead, follow or get the #^%# out of my way!!!!!!
        It can be a "mid year" change, like the tubeless rims in 1979. As I said, I didn't think they had them, but I have a 1978 and a 1979, both WITH the ballast resistors.
        Was your resistor located on the left side?
        • eroellig
          • 229
          • Arkansas
          Ray, my resister was in the usual place with the usual colors on the wires.
          Eric
          Eric Roellig
          **Very first bike**
          • AlanB
            • Oct 2006
            • 705
            • Scotland
            Hi Guys,
            My SG has one too.
            AlanB
            If it ain't broke, modify it!
              Re: Ballast resistor...
              Hey Mike,
              Here's a photo from the Dyna Coil upgrade tech tip that shows the ballast resistor, just below the left tank rubber mount!
                My sg had one, my H did not. It may have something do do with the ignition and black box changes with the 81 models.
                • boyat68
                  • Oct 2007
                  • 358
                  • Virginia
                  My 80 G has one, and the manual's electrical schematic shows one for the G, SG, SF, and E 1978 through 1980.
                  • boyat68
                    • Oct 2007
                    • 358
                    • Virginia
                    Looking at the manual the second time the F also has one.
                      The resistor was done away with for the 81 model year (H & SH), the same as the 2h7 ignition module was replaced with the 4R0 module in 81.
                      • Crazcnuk
                        • 2980
                        • Hinton, AB, Canada
                        My G has one as well...
                        Another myth quashed!
                        '05 ST1300
