rear wheel rubbing
  • rman
    • 228
    • Stroudsbug PA
    rear wheel rubbing
    Hello, and please help.
    I have been working the bike recently and noticed some drag at the rear wheel. This might account for my 22MPG last season.
    I am posting two picture that show the orientation of the brake caliper support assembly. I think that this is incorrect and that the spacer needs to be moved to between the wheel and the assembly and not the wheel then assembly then spacer.
    If anyone knows if this is right or wrong or even has a picture of this assembly handy I would apriciate the assist.
    Thanks
    Ray
    Trying not to offend since Aug 28, 2010
    Disclaimer: I am an idiot. Pay no attention to the man behind the curtain.
    Owner of:
    1979 XS1100F (The Pig)
    140 mains
    45 pilot jets
    Floats at 24mm
    Running Rich
    "Arrogant, delusional tyrants can't be stopped by earnest words and furrowed brows. Action, strong bold action coming from a position of strength and determination, is the only effective deterrent." -Mitt Romney
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    "Interesting..."
    No, the order is correct.
    Now then... hard to tell by the pictures.... but you may be missing something.
    If you have your Clymer's manual handy... page #215... part #4, shaft collar. Hard to see if it's there or not so I went to my bike to compare.
    Of course... My bike's axle area is a LOT CLEANER!!!!!
    Meaning... and you can see it from your pictures, the center hub area of the rim, and the lower part of the torque plate, etc are grease stained.
    No, it looks like you have all the correct parts, and have them in the correct order... but all that staining could mean you have a failed wheel bearing. I'd say it failed, heated up, melted the grease, grease slid past the oil seal, etc.
    • AlanB
      • Oct 2006
      • 705
      • Scotland
      Hi Rman,
      Right number of parts..... possible the wrong parts! Standards a nd Specials use different size spacers; Prom may be right (as usual!) or the spacer between wheel and brakeplate may be too slim?
      AlanB
      If it ain't broke, modify it!
      • rman
        • 228
        • Stroudsbug PA
        Prometheus578
        Hmmm, well yes there could be a bad bearing as well. But the break rotor is rubbing against the caliper bracket. See top of rotor.
        When I was looking at the drawings I cannot see how the caliper bracket fits into the sequence when only the torque bracket is shown.
        In my second photo from right to left I have the cinch bolt then a gap, then torque plate, then the collar and then the caliper bracket then it looks like the oil seal. I may just be seeing things wrong.
        Owner of:
        140 mains
        45 pilot jets
        Floats at 24mm
        Running Rich
        • rman
          • 228
          • Stroudsbug PA
          snakes and arrows
          Ok got some arrows into the photo to show my areas of intrest. Red arrow is the rubbing rotor, green is the gap, yellow is the spacer.
          Owner of:
          140 mains
          45 pilot jets
          Floats at 24mm
          Running Rich
          • randy
            • Dec 2003
            • 4521
            Ray, why don't you bring it over and we'll have a look?
              I don't know if the standard is different from the Special in regard to the order of spacer, caliper bracket, and torque plate, but I just checked all three of my Specials, and that is the sequence of the components, from the inside out.
              • randy
                • Dec 2003
                • 4521
                Ray, I just checked my 79F, and you have the parts in the right places. I think the wheel needs to come off to check if you have the bearing spacer in there. In the center of the oil seal there is another spacer. If it's missing, that may also be why you've got leakage there.
                • prometheus578
                  • Aug 2004
                  • 4012
                  • Olympia , Wa.
                  That's what I was thinkin', Randy. It's just too hard to tell from the pics.
                  When he's got the wheel off, check to make sure the tubular spacer is in the wheel hub between the wheel bearings. I've seen people leave that out before when changing bearings.
                  • eroellig
                    • 229
                    • Arkansas
                    Re: rear wheel rubbing
                    Thanks
                    Ray
                    A different Point-Of-View.
                    When I got my bike, the PO hadn't done ANY maintenance in the 8 years he owned it. I noticed that it seemed like it didn't want to move very well. The answer was that the back brake caliper wan't releasing and the brake was dragging. It seems that the PO hadn't noticed and just opened the throttle a little more as the back brake pads only had a couple of paper thickesses left and the rear rotor is worn almost to the minimum tolerance.
                    A rebuild/cleaning of rear MC and caliper (and new SS lines ) worked wonders.
                    Any chance of this on your bike?
                    Eric
                    Eric Roellig
                    1980 SG w Windjammer V & KG hard bags
                    **Very first bike**
                    Current condition: Running!!! Lead, follow or get the #^%# out of my way!!!!!!
                    • randy
                      • Dec 2003
                      • 4521
                      Prom,
                      I was thinking that too, but if the center bearing spacer was gone, the roller bearing would come apart. There's nothing holding the inner roller in that bearing except for that middle spacer.
                      The roller bearing coming apart in that way would cause a hell of a wobbly, grinding, crunching horror sound.
                      • prometheus578
                        • Aug 2004
                        • 4012
                        • Olympia , Wa.
                        Yes, but.
                        I've seen people put the wheel together without that inner spacer.
                        "Gee, when I tighten the axle nut, the wheel doesn't move."
                        So they don't tighten the nut too much and then ride.
                        But it is tightened. This pressure then, would force the brake mounting componets inward, stressing the wheel bearings... the inner roller...
                        It would then heat up, melt the grease and the oil seal, resulting in the staining we see in the photos.
                        Yes, eventually, the bearing would come apart resulting in the cool audio noises you demonstrated but the bike would have been rideable for some time prior.
                        In another thread, I mentioned the Victorys with the wrong length spacer between the wheels. They, on average failed at the 20,000 mark. Now then, they did have a spacer, (though a little too short) to take the sideward bearing load... we'll just have to wait and see.
                        Looking at those pics again... the grease staining tells me there's something not right with the bearing. May not have been the cause... but it's now affected.
                        Unless, or course, someone is just a sloppy greaser.
                        • mro
                          • 4276
                          • Hayward, California
                          Has the nut been torqued properly?
                          mro
                            • 7830
                            MRO
                            Has it been torqued in the PROPER ORDER? You need to torque the axle nut, and THEN the pinch bolt. My machine had both front and rear tightened in the wrong order, and it was a mess!
                            • rman
                              • 228
                              • Stroudsbug PA
                              problems still
                              Hello,
                              I have recently returned from a three week stint at Delta Junction Alaska. It was cold and snowy. I much prefer the 70+ temps and clear blue skies that I have returned to. Took the bike out for a 65 mile ride yesterday and felt the rear rotor. it was barely warm to the touch and the brake pads that I put in last year still look good. The bike only got 20MPG during this run and was unable to exceed 85MPH
                              I hope to get some time on the wrenches soon but this weekend being passover my SWMBO has my social calender filled up.
                              I hope Randy might be available to take a look and let me know what needs to be done. Any time open in your schedule Randy?
                              The wheel seems to spin ok when up on the center stand so I am not sure that the problem is a bad bearing or just an idiot behind the wrench.
                              Thanks for all of the input everyone.
                              Owner of:
                              140 mains
                              45 pilot jets
                              Floats at 24mm
                              Running Rich
