A Standard tank will bolt on with only slight differences. The seat to tank fit will be different and some rework of the fuel lines will be required (by-pass the Special’s octopus).
one of the first things that was done to the bike was to simplify the fuel lines. I also had a the seat modified to suit my needs. I am vertically challenged. The larger tank simply fitted in place.
