Oily Engine Front
  • AustinPhoenix
    • Mar 2008
    • 112
    • Austin, TX
    Oily Engine Front
    I just picked up a super nice 80 xs1100g, but it doesn't run. There's a lot of grime on the front of the engine and I haven't cleaned it to see where it's coming from just yet. It doesn't start right now, but I'll mess with it this afternoon. It sat for 9 months.
    I'm thinking I'm going to have to remove the tank for cleaning, same with the carbs, check the battery, change the fluids, and see where the leak is at. Anything else I should look for?
    The guy I bought her from had the final drive rebuilt, 4 to 2 exhaust, new head gasket, fork seals, tune up, tires (but the rear won't hold air), and new battery (low on water right now).
    How many components are compatible from a 79 xs1100 to this one?
    Thanks all!!
    1980 XS11g Standard - "Ash"
    4 to 2 Exhaust
    K&N Pod Filters
    Fuel Filters
    Inline shut off valves
    Slotted Rotors
    My heart and soul
    Soon to have stainless lines, xs750 FD, lightened rotors, and HID headlight
    1979 Special Project Bike
    Non-gasoline conversion
  • John
    • 5117
    I would look at the cam chain tensioner as the likely culprit causing the oil leak. The rubber plug at the end of it may have fallen out. It is located on the front of the engine, between #2 & 3 exhaust pipes. Do a search on the tensioner, and you will find many posts on the subject.
    Many 79 F will fit on the 80 G, jus depends what part it is.
    • mro
      • Oct 2005
      • 4276
      • Hayward, California
      Have you read this?
      Is the 79' a special or standard?
      80 is when the carbs changed to the BS34 III's, cams and pistons changed too. Still there be many parts that will interchange and can swap a full carb bank between years.
      mro
      • AustinPhoenix
        • Mar 2008
        • 112
        • Austin, TX
        Tensioner
        I was going to ask about that. I was cleaning around it and noticed most of residue was right around it. Thanks for the pointer!
        The guy laid it down before parking it. The only damaged part that concerns me is the left side cover with Yamaha stamped into it. It's rashed through. Is that the clutch or crank cover?
        4 to 2 Exhaust
        K&N Pod Filters
        Fuel Filters
        Slotted Rotors
        My heart and soul
        • mro
          • Oct 2005
          • 4276
          Crank/timing cover
          mro
          • AustinPhoenix
            • Mar 2008
            • 112
            • Austin, TX
            Thanks MRO...the guy said clutch...but I'm new to these bikes and took his word for it.
            Thanks for the link as well.
            Should I look online for the replacement to the tensioner rubber piece or is there a suitable replacement elsewhere?
            4 to 2 Exhaust
            K&N Pod Filters
            Fuel Filters
            Slotted Rotors
            My heart and soul
            • webbcraft2150
              • Sep 2002
              • 1605
              • AUSTIN.TX
              Common and easy fix for a leaky tensioner is clean the hole with brake clean real well and fill with high temp silicone sealer. Been holding for years on my G. Or, you can get the right seal and replace it. The silicone trick requires no disassembly. If you remove the tensioner, follow the tech tips. You can inflict some major damage if you do it wrong.
              • AustinPhoenix
                • Mar 2008
                • 112
                • Austin, TX
                Thanks for the tip! I love the search function on forums...you all have a tremendous amount of knowledge. Thank you!
                4 to 2 Exhaust
                K&N Pod Filters
                Fuel Filters
                Slotted Rotors
                My heart and soul
                • BrianB
                  • 362
                  • Idaho
                  Last Summer when I first got my bike, it was leaking at the cam chain tensioner as well. The plug was hard and brittle. I did a good cleaning of the area and replaced it with a new plug. I was able to order the new plug from our local Yamaha dealer for just a few bucks. No leaks at all now.
                  1980 XS Eleven Special
                  • AustinPhoenix
                    • Mar 2008
                    • 112
                    • Austin, TX
                    hmmm
                    I cleaned the bike's front pretty well last night, but the little black plug is still in the tensioner. I guess I'll find out where it's coming from tonight when I get home. I has to be somewhere on the left side because there is slight oil residue on the bottom of the entire left side, but not the right.
                    Where does everybody get their replacement parts from? Ie. carb rebuild kits, caliper rebuild kits, etc Like anybody, I look for the best prices on everything.
                    4 to 2 Exhaust
                    K&N Pod Filters
                    Fuel Filters
                    Slotted Rotors
                    My heart and soul
                      • 8629
                      rebuild kits
                      Partsnmore.net has good deals on carb and caliper parts.
                      โ˜ฎ
