So, things have worked out with the MSD (another story) enough to get to test out my AEM wideband O2 system. The AFR's I got on my first test ride were both good and bad. From what I can tell, through the low and mid range (<5k) with a load, the bike is rich with AFR's run from around 11-13. At WOT, the bike leans out as the RPM rise and at about 7k, the AFR gets right around 14.
Currently, I am running 117.5's with 45 pilots, 4-1, and pods. This, I believe, is in accordance with the jetting guide.
Why is it, that on the Factory Pro tuning page, they do not even mention the pilots in the whole tuning process?
Not to mention, they recommend adjusting the float height as a way to tune the LOWER rpm...? What the heck?
What is the optimal performance AFR?
Should I go back to my stock pilot, or drop the float level?
Not to mention, they recommend adjusting the float height as a way to tune the LOWER rpm...? What the heck?What is the optimal performance AFR?
CV! and the fuel curves are built in to the metering system including the design and taper of the needle.
