It's time to polish up the aluminium on the bike. The timing and valve covers come off easily enough. I want to remove the crankcase covers on both sides and do a full job while my enthusiasm holds up. When I have drained the oil, what is involved in removing the "wet" covers? Is there anything likely to fall off when I do this? Any seals, like around the gearshift and kickstart that will tear and need to be replaced? Any springs that will fly across the shop? Any need for specialized pullers, or will they just pull off by hand/ slight persuasion?
Thanks,
Gareth.
Thanks,
Gareth.
And then the lever and throwout rod won't work right IF you don't realize that it has occured! The Manual describes this pitfall, but don't know/think that you have one?
