jetting recommendations help
  • rizzo4u2
    • Nov 2007
    • 49
    • hanover,pa.
    this forum is not excepting no more questions,want to rejet , need to no what sizes to go to for , so far im running an accel140403 kit ,k&n filter , i drilled the air box ,but still running stock exhaust, thinking on getting a new set whats best for this application, and were would be the best place to get theses different size jets,
    mike.s
  • 81xsproject
    • 3185
    • Fortuna, CA
    I would go up at least one size in the mains and possibly raise the fuel level .5-1mm. Someone recently recommended this site. Jetsrus.com
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • audijunky
      • Apr 2006
      • 707
      • VA
      Mikesxs.com has the mains
      79 XS1100 modified standard
      straight pipe 4-2 exhaust
      Owned 83 Honda V65 Magna
      Owned 02 Vstar 650 classic
      owned 85 Honda Shadow VT 700C
      • rizzo4u2
        • Nov 2007
        • 49
        • hanover,pa.
        jet sizes
        are these mains large or considered small when ordering through mikes xs, thankyou mike s.
        mike.s
        • audijunky
          • Apr 2006
          • 707
          • VA
          Dont really know what you mean? Look for main jets for the BS34 carbs. look like a small bolt with a hole in the center. Whatever size you have has a # on it. If you need more gas you get some with a larger #, or less gas some with a smaller #. If by large or small you mean actual overall size, they are small.
          And if you need pilot jets(even smaller) bike bandit.com has them. look under the Mikuni section.
          • audijunky
            • Apr 2006
            • 707
            • VA
            And if you haven't seen this it may help
            • red bandit
              • 970
              • central michigan
              Large.
              But I think the small will work too??
              79 SF parts bike.
              • audijunky
                • Apr 2006
                • 707
                • VA
                Oh yeah, red bandits post just reminded me. I have quite a few different sized jets. the ones I have in now are 150, and are a smaller outside diameter then the others I have. they work fine
                  Hey Rizzo,
                  You want the LARGE HEAD jets for the mains!
