As some of you know, I've been fighting with my carbs. Upon the advice of TC and others, I lowered the fuel level in each carb. However, I think I went too far. So I must ask: what are the symptoms of fuel level being too low?
You see, with the new fuel levels, my bike starts and idles super smooth. Even after only bench synching, it idles smooth. When the engine is under load, however, it pops and sputters from the pipes and the carbs. Only after about 3000 rpm does it kick in and run with power, though still sputtering slightly.
I'm almost certain these ailments are from the fuel level being too low. But why does it gain power after 3000 then? I realize thats when the needle starts to flow more, but how does it flow more if their is no fuel to flow?
My plugs are towards the whitish side, however, which reaffirms my suspicion of a lean condition.
Would out of synch carbs cause problems like this? I have only bench synched them, remember.
do you have a stock exhaust and air filter?
