I've been looking for a few months now and the choices are getting fewer and fewer. Jardine no longer manufactures them. I believe MAC still makes them. Bike bandit is the cheapest I've seen for this one. Jardine 4 into 1 Who knows if they have any more in stock.
If your header pipes are still good, you may find some slip-ons from time to time on ebay and there's a thread here on XS11.com that talks about using Harley mufflers. Good luck with your search!
Tim Ripley - Gaithersburg, MD 1981 XS1100 Special "Spoiled Rotten" Just sold - currently bikeless!!
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fix
Hey, I had 2nd dibs.....seriously I really like the look of those, but I'm not sure I could use them, looks like they would set way to low for comfort with my new front end....Very cool pipes tho, mro
MDRNF
79F.....Not Stock
With a lowered bike, would be a problem.
Is speed bump challenged as is altho I have not had any problems. Have been thinking that this one XS might be cool to mod some as it is far from stock now. Inspirations from chop and the guy with the "mad mosquito" in mind.
Originally posted by mro ......Inspirations from chop and the guy with the "mad mosquito" in mind.
mro
I am that guy! And yes my Kerker is already too low for speed bumps and it's hugging the oil pan! I guess they would be too low for the Mad Mos....that's what I'm telling myself at least to make me feel better.
1979 XS11 Special (slightly modified)
dubbed the "Mad Mosquito"
MikesXs Pod Filters
MikesXs 35k Coils
8mm plug wires
42.5 Pilots 142.5 Mains
(Carb tune by GNEPIG Performance)
Kerker 4-into-1
Shaved emblems
Progressive frt springs lowered 1.5"
Progressive 11.5" rear shocks
Harley Dyna rear fender chopped
Custm side mt tag (apparently illegal)
Custom Dual Headlights
Lots of time and hard work.
I found my solution to my 4-2 problem at O-reilley's auto parts. Will be able to keep my 4-2's and still look mean after I cut off the ends to clear the swingarm. I will post in new thread later. Those really are some trick looking Bassini pipes and would look great on the Flat black scheme I got goin'.
MDRNF
79F.....Not Stock
Years ago i took an 1100 SUZUKI AND CUT THE HEADER PIPES SO THEY WERE SINGLE PIPES THEN I PUT 4 SHORTY MUFFLERS ON IT. it was very loud but i was into that at the time it looked real good though and the mufflers you can still get at any bike shop cheap for like 30 bucks apiece. just a thought.
Doug
Doug Mitchell
82 XJ1100 sold
2007 Stratoliner 1900 sold
