Yesterday, I tried to start the 79SF after leaving it sit indoors for the past four months. The bike started and ran for a few seconds then quit. I continued to crank it for a while and I guess I flooded it. When I hit the the kill switch , there was a massive backfire on the right side. In the confined space of the workshop it about made me jump out of my skin. I let is sit for a while. I turned the key this time to let it sit...and another almighty bang.
At about the same time, fuel started leaking from the airbox. I figured that there was probably a stuck float valve on that side. Today, I pulled the carbs and checked the float valves and reset the float heights. When I put the carbs back, convinced the flooding was the problem, the bike wouldn't start.
There is no spark at any of the four plugs.
I'm just going to assume that the backfires were caused by some high-voltage discharge when I turned off the low-voltage with the key or the kill switch.
My question is... could that same high-voltage pulse have fried the TCI or some other vital component?
There were intermittent problems with the bike dropping cylinders before I put it away a few months ago, but I had assumed this was just fuel problems. Now I am not so sure.
The backfire problem did happen a couple of times in the past, but now I'm wondering..
Has anyone any ideas??
Regards,
Gareth
Regards,
Gareth
