brake lines
  • audijunky
    • Apr 2006
    • 707
    • VA
    brake lines
    found some on the web for the xs750,and 850.
    Will these fit an 11?
    brake lines
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
  • randy
    • Dec 2003
    • 4521
    If they fit, those are good prices. Here are the measurements we use, all are center-to-center of the banjos, why don't you ask them what their measurements are?
    Standard:
    M/C - 16"
    Front Calipers - 22-3/4"
    Rear: 19"
    Special:
    M/C - 20-1/2"
    Rear: 19"
    • audijunky
      • Apr 2006
      • 707
      • VA
      Why don't you??? haha just kiddin, I 'll get right on it and post up some results
      • audijunky
        • Apr 2006
        • 707
        • VA
        email sent
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          those lines
          I posted about those lines before. I had a complete set and they bolted right up. I see the price went up a little, but still the cheapest deal in town. with the stainless lines and drilled rotors stoppies can be done with one finger on the trigger....
          MDRNF
          79F.....Not Stock
          • audijunky
            • Apr 2006
            • 707
            • VA
            which ones, the 750 /19?? or the 850/19??. from what year. I am going to order a set if you can give me specifics.
            thanks Chop
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              lines
              IIRC the 850 lines were the same and fit the xs11 STANDARD perfectly. the xs11 special needs longer upper MC to tee. I can ask my friend he also has a standard front end and he got the same kit.
              MDRNF
              79F.....Not Stock
              • Cobia
                • Jul 2007
                • 1587
                • Palm Beach County, Fl
                There's a difference on how the lines are put together.
                I was advised by a mech friend to be sure to get the SS Braided hoses with fittings that are compressed to the end of the hose insead of the scew-on compression gland type. I saw both types and the compressed fittings are more compact as well, and according to him not prone to vibrate loose/apart. Makes sense to me. Any experience with these?
                1980G Standard, Restored
                Kerker 4 - 1
                850 Rear End Mod
                Automatic CCT
                1980GH Special, Restored
                '82 XJ1100 (Sold)
                • audijunky
                  • Apr 2006
                  • 707
                  • VA
                  this is what they wrote back. specs for there lines
                  Here are your specs:
                  PPB-YXS750SF79C: 1 ct, 10mm banjo 10 deg bend x 10mm banjo 20 deg bend, 19-1/2" OAL
                  Orientation: 10 deg up x 20 deg down same plane.
                  1 ct, 10mm banjo 15 deg bend E/E, 17-7/8" OAL
                  Orientation: 15 deg up x 15 deg right 90 degree offset.
                  1 ct, 10mm banjo 10 deg bend x 10mm banjo 20 deg bend, 21-3/8" OAL
                  1 ct, 10mm banjo 10 deg bend x 10mm banjo 20 deg bend, 21-5/8" OAL
                  PPB-YXS850SG80C: Upper Front:
                  1 Ct. -03 Teflon hose, 10mm banjo 20 deg bend by 10mm banjo 35 deg bend,
                  20" OAL center of banjo to center of banjo.
                  Orientation: front master to junction box
                  20 deg facing up & 35 deg facing downward at 5 o'clock
                  Rear Hose
                  1 Ct. -03 Teflon hose, 10mm banjo 20 deg bend each end
                  19" OAL center of banjo to center of banjo.
                  Orientation: rear line
                  20 deg up & 20 deg downward to right at 4:30
                  2 Ct. -03 Teflon hose, 10mm banjo 20 deg bend by 10mm banjo 35 deg bend,
                  21-3/4" OAL center of banjo to center of banjo
                  Orientation: front right 20 deg up & 35 deg downward left at 7 o'clock,
                  Front left: 20 deg up & 35 deg downward right at 5 o'clock
                  PPB-YXS850G81C: Front:
                  1 ct, 10mm banjo 20 deg bend E/E, 19-1/2" OAL
                  Orientation: 20 deg up x 20 deg 90 offset bend to right.
                  Rear:
                  1 ct, 10mm banjo 35 deg bend x 10mm banjo 20 deg bend, 16-1/2" OAL
                  Orientation: 35 deg up x 20 deg 2 o'clock bend to right.
                  Right:
                  1 ct, 10mm banjo 35 deg bend x 10mm banjo 20 deg bend, 20-3/4" OAL
                  Orientation: 35 deg up x 20 deg down same plane.
                  Left:
                  Orientation: 35 deg up x 20 deg 2 o'clock bend down right.
                  If We don't have the configurations for the lines you need. If you are able to provide us with the exact specifications (end fittings, overall assembly lengths, any center line bracketing), we can see if the fittings are available to fabricate the kit for you.
                  For help with fitting configurations, please visit our brake line fittings photo pages at:
                  Another option is to take good digital or scanned photos of the lines, esp. the end fittings, and email them to us. Of course, sending us the actual lines for evaluation and/or duplication is the very best way to get the perfect fit.
                  If you have any other questions please give us a call.
                    • 8050
                    scrap lines
                    Does anyone here have a scrap set from a Special? I need to replace my lines and soon. It would be good to get them exact.
