Cross Drilled Rotors Poll
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    I am thinking about programming my CNC machine to cross-drill XS Rotors . I figure I gan get them done for about $40-45 each (I break/fry a tool on these tough rotors) with the standard pattern I used on my last set that took a long time to do on the incremental drill press. This lightens the rotors and increases stopping power and decreases heat/ brake fade....Let me know here if interested....chop
    MDRNF
    79F.....Not Stock
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    I be up for getting mine done!!! While your at it, figure out how to blanch grind em smooth again to.
    • Da-Bubble
      • Jun 2006
      • 353
      • Oklahoma City, OK
      I might be interested. Could it slot them too?
      1979 XS11 Special (slightly modified)
      dubbed the "Mad Mosquito"
      MikesXs Pod Filters
      MikesXs 35k Coils
      8mm plug wires
      42.5 Pilots 142.5 Mains
      (Carb tune by GNEPIG Performance)
      Kerker 4-into-1
      Shaved emblems
      Progressive frt springs lowered 1.5"
      Progressive 11.5" rear shocks
      Harley Dyna rear fender chopped
      Custm side mt tag (apparently illegal)
      Custom Dual Headlights
      Lots of time and hard work.
        "I might be interested. Could it slot them too?"
        A CNC mill should be able to slot rotors as well as drill them. I have seen vulgar pictures milled in rotors offered on e-bay, come to that.
        Thing is, my XS11 has factory slotted disks and I have drilled my own XS650 disks tears ago. The Yamaha disk material is tougher than old boots BTW. Slow cutter speed & flood coolant works best for drilling & presumably for slotting as well.
        And they are a bitch to re-surface, the rotor resurfacing lathes in brake shops make them look like a ploughed field.
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          Make 'wm smooth
          I have had good luck grinding them in a lathe with a toolpost grinder setup.
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            Drill Pattern
            This will be the Pattern and .25" hole sizes. On the rear rotor I added two opposing .5" holes for a wheel lock....
            MDRNF
            79F.....Not Stock
            • ScottsXS
              • Sep 2005
              • 169
              • Demotte, IN
              i would be game!! keep an up date
              when in doubt...get a bigger hammer
              '78 XS11e, '79 XS11sf,'81 Mazda RX7, '83 XJ650lj Turbo, '95 Ford F150, '93 Chevy K2500, '04 Honda Pilot,
              '89 Arctic Cat Wildcat, '89 Arctic Cat El Tigre 530, '81 Arctic Cat Trailcat 340, '79 john deere trailfire 440,
              '78 Cadillac Seville
              Don't steal the government hates competition
                • 6763
                My '81 XS1100SH has extra slots on the rotors look closely
                2005 Honda SilverWing 600
                2018 Honda PC-Xpress 150
                • Pat Kelly
                  • 3046
                  • Golden Valley, AZ
                  I drilled my own rotors with a bench-top Craftsman drillpress. Used one small bit for pilot holes and larger bit for final holes. Used plenty of cutting oil and good quality bits and had no problems. All 3 rotors took about an hour to drill.
                  You can see the holes get progressively larger from inner to outter. All holes are chamfered and all holes overlap around the diameter.
                  Pat Kelly
                  <p-lkelly@sbcglobal.net>
                  1978 XS1100E (The Force)
                  1980 XS1100LG (The Dark Side)
                  1999 Suburban (The Ship)
                  1994 Dodge Spirit (Son #1)
                  1968 F100 (Valentine)
                  • mro
                    • 4276
                    • Hayward, California
                    Sorry chop...could not resist
                    Holey Rotors Pat....
                    Na...Na...Na.Na..Na
                    Mine be Holeyer than tho's Pat
                    mro
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      Personally, I would want more or bigger holes. However, I decided that I would just suck it up and hold out to spend the big bones for the EBC floaters.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
                      • Dennyz
                        • 1151
                        • Olympia, Washington
                        A show your drilled rotors thread!
                        They really improve braking in the rain.
                        DZ
                        Vyger, 'F'
                        "The Special", 'SF'
                        '08 FJR1300
                          I got my inspiration for drilled rotors from Denny when I saw his bike at one of the PNW rallies at Sid's place. If you don't already have a cheap drill press and an expensive drill bit sharpener, this would be a pretty fair price for getting your rotors drilled. My only regret is I did not think of drilling graduated hole sizes when I did mine.
