Thanks 81xsproject,
I take it then, that you didn't have to bend the tang very much? When I put a viton tip valve in the 79 seat the float went from ~25.7mm to over 31mm.
If I use the xv920 setup with my 80/81 plastic floats do I set them at 25. 7mm for the 79 or do I go to the lower setting of ~23 for the 80 or do I trial and error it?
