Just did the second gear fix. It's nice to have a strong second gear again. Thanks to all the folks on this forum for making that procedure so clear. Went ahead and put new friction plates and springs in the clutch too while I was at it. It got up to 60 degrees yesterday so I got in a nice ride!
Does anyone know if you can replace the rubber drive boot between the middle drive and the rear swing arm without removing the arm and/or the driveshaft? If I just remove the 4 bolts at the middle drive u-joint, will I be able to squeeze it in there?
. I have the new drive boot and everything, I just haven't had the time to fiddle around and see if I can get it in there. Hopefully someone who's replaced it will chime in here, I'm hoping it's relatively quick and easy. If I get a chance to go mess with it I'll post what I find out.
