I have thought a bout changing to allen capscrews but I am not sure about how delicate the threads in the head are. So I decided to stay with the studs.
Whenever I remove the exhaust I make sure to put some anti-sieze compound on the threads before I install the nuts again. Seems to keep the high heat from affecting the nuts when it comes time toremove them again.
Mike Giroir
79 XS-1100 Special
