cleaning suggestions
  • geniusloerts
    • Jul 2007
    • 420
    • fayetteville, Arkansas
    just a a quick question, how does one switch out the shims once the cams are reinstalled, or do you have to pull the cams again to tp swap the shims?
    1979 XS1100 SF "Black Goblin"
    -Pod Filters
    -4-1 pipe
    -larger jets for carbs
    1982 XJ1100 "Black Sheep"
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      I would spin the engine by hand several times to fully "seat" everything and then measure the valve clearances. If you recorded the existing shim sizes before putting it back together you will be able to figure out what you need. You can remove the cams again for the shim change out but there is a tool designed for doing the job while the cams are in place.
      On a different note for anyone who is doing valve re & re work DO NOT LOOSE or FORGET to re-install the STEEL washers that go at the bottom of the spring bores!! If you do ... the springs will pound their way through your head in short order.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
