reserve lighting unit
  • reserve lighting unit
    im installing a HID kit and have read that its good to remove the reserve lighting unit. It just looks like there is a pin connector that goes into it but it no wires coming out of the box. im assuming i can just unplug it and remove it and thats it???
    79 standard
    kerker 4 to 1
    K & N drop in
    6K HID
    frame chopped with one of a kind seat
    may other upgrades....
    Hi Brew,
    Not quite that simple; two of the wires need joined to give lights. Try a search on the forum, you will find which pair.
    AlanB
    If it ain't broke, modify it!
      so is it really necessary to take this out to install my HID kit?
      79 standard
      kerker 4 to 1
      K & N drop in
      6K HID
        Brew
        The RLU is a cunning little device that we Brits are becoming quite expert at removing or circumventing... :cool
        The problem when fitting the HID kit is that the RLU is designed to switch a reduced supply voltage to the "other filament" (depends if you're riding on hi or lo beam when the bulb blows
        This reduced voltage is unlikely to be high enough to feed your HID lamp ballast unit, so the lamp won't fire up...
        You could get around the problem by using the RLU to switch a relay between hi/lo circuits and feed the relay direct from the +12V... The reduced voltage would still switch the relay, the HID ballast would still get +12V and your RLU and bike wiring would remain mostly unmolested...
        Just a thought... Goo Luck...
        Miti
        One of those terribly nice chaps on XS1100.com
        • XS1100S (5K7) '83 "Sport #1 - Trike Donor"
        • XS1100S (5K7) '85 "Sport #2"
        • XS1100LG (4W1) '80 "A Tribute to Brian"
        • Hesketh V1000 '82 - Dream Realised...
