Carburetors
  • Getty
    • Feb 2008
    • 127
    • Denver, CO
    Carburetors
    I have almost successfully disassembled the carbs while performing the tasks mentioned in the book. I went a bit to far and started removing the choke rod. Well after almost loosing the ball bearing and ruining one of the choke rod screws. I put it back together less on screw. The screw had a replacement, but it to has been discontinued. Do you guys know where I can find the screw?
    Then followed "Removing and Cleaning your XS11 Carburetors" by Maans Smit
    Good thing the kit Part #48-1408 I ordered has a new gasket. The old ones are totally destroyed. Question about the float seats. Do they come with the screen? Or, do I need to salvage the old ones?
    I didn't break anything else (HURRAY) removed all the parts Maans Smit mentions.
    After this thing is all cleaned up should I set the float height? Should I try to do the bench sync? I would think the old settings would work until I do a real sync while running.
    Getty
    1980 SG
  • Getty
    • Feb 2008
    • 127
    • Denver, CO
    I forgot to mention that the #1 and #2 slides were not sliding well. Im think this is why the bike didnt run well.
    They mention using baby oil on the slides. Is that ok or shoul i use something else?
    Getty
    1980 SG
    • randy
      • Dec 2003
      • 4521
      Getty,
      I have extra choke rod sets screws.PM me your address and I'll mail you a couple.
      Save the screens on the float seats, new seats don't come with the screens.
      Never heard of using baby oil on the slides, but I don't think it would hurt anything. Regular motor oil would probably do just as well. Eventually whatever lube you use will be diluted by gas and burned away anyhow.
      • Getty
        • Feb 2008
        • 127
        • Denver, CO
        Randy,
        The article by Maans Smit mentions using baby oil instead of other thicker oils, because they form heavy residue.
        I think he may be on to something. #1 and #2 had thick droopy dark rings. The dark rings of droopy oil were definitely the cause.
        Getty
        1980 SG
          When I rebuild carbs, I do not put ANY oil in them. If everything is cleaned properly, they will work. If I need some on the enricher, I use a silicone base oil on the two "stops". This keeps the rod moving easily, even after riding in the rain.
            Hey Getty,
            The Goopy stuff is probably varnish from the fuel, not necessarily oil residue. Once it's cleaned off properly, along with the carb body slide tunnel, then it should slide very easily and no oil is needed. And you want to be careful not to get oil on the vacuum rubber diaphragm.
            Besides the ball bearing, there is also a little spring that is/was behind the ball bearing, so you'll want to make sure it didn't SPROING away!
            • Getty
              • Feb 2008
              • 127
              • Denver, CO
              My spring sprung a long time ago. But the little on is safe.
              Great tutorial on the pre sync. Not to sure of the idle. It should dial in nicely once started.
              Float adjustments: Was a little scared about this one. Just realized that I have to adjust the floats. What is the specification for the 1980 SG special?
              Getty
              1980 SG
              • Getty
                • Feb 2008
                • 127
                • Denver, CO
                I got the spec 25.7mm +/- 1mm.
                The manual that came with the bike is for a different year. I feel much better after looking at the correct manual.
                Getty
                1980 SG
                • corey
                  • Mar 2005
                  • 208
                  • Dexter, MO
                  I have later model carbs on my 79XS1100SF special and I set my floats to 23mm +/- 1mm. Works pretty well for me!
                  Its not too scary, just be ginger with the tangs. Also, inspect the tangs for warn spots. Just the slightest spot might grab the needle causing it to seat cock-eyed, thus making your carb puke up gas!!
                  Corey J. Bennett
                  '79 XS1100SF
                  • TADracer
                    • 1417
                    • Kenner, Louisiana USA
                    I believe the two small balls and springs onthe enrichener rod are still available from Yamaha. I think they come in packs of five so you get the chance to lose a few of them again.
                    I did change out the set screws using some allen set screws I purchased at the hardware store.
                    Mike Giroir
                    79 XS-1100 Special
                      The float setting for the 80 SG is 23.5 mm, plus or minus .5 mm.
                      • Getty
                        • Feb 2008
                        • 127
                        • Denver, CO
                        Job well done.
                        Thank you guys for being so supportive. I followed the tech tips, manual, and all of your suggestions. Finished the carb cleaning / rebuild tonight. The bike really performs well.
                        Pre Sync - Did it with the bag wire. It worked well. But, I can’t tell if I made a small hole or the PO did. Then I did the three-hole test. That works amazing!
                        Float Height Adjustment - The supplement manual I pulled from the website listed http://search.ebscohost.com/Login.as...uthtype=ip,uid (library, library)Manuals ** 23mm as the desired height. I didn't have the special measuring tool. The ruler I had didn’t work well. So I used one of the toothpicks soaked with carb cleaner to make the adjustment. Set the toothpick on my rule and marked the desired height 23mm. Worked for me.
                        HURRAY!! I feel really good about this.
                        Getty
                        1980 SG
                        • Getty
                          • Feb 2008
                          • 127
                          • Denver, CO
                          Dont worry about sending those enricher set screws. I bought one from the hardware store.
                          Thanks again. I owe you some money if you sent them allready.
                          Getty
                          1980 SG
                          • randy
                            • Dec 2003
                            • 4521
                            Getty, I put the screws in the mail on Saturday. Just hold on to them and if someone wants them, send them out.
