carb identification
  • eric
    • Feb 2008
    • 2
    • South Africa
    carb identification
    I have an XS 5N5 000656
    i have rebiult and still going but now the carb is giving problems
    from what i can see (South Africa)
    it is an 81 RH model
    the carb has no marking and i need to replace a jet and few things
    I am trying to find what carb should be on the bike and what size jets etc should be in it..
    at the moment someone has fiddled and the jets and things are mismatched
    many Thanks
    eric
  • red bandit
    • 970
    • central michigan
    What jets do you have? A pic of carbs might help incase someone swapped em. Not familure w/ RH, but if that is a special the #2-3 carbs are larger jets than 1-4 to keep them cooler. BUT I don't know about foreign models.
    79 SF parts bike.
    • eric
      • Feb 2008
      • 2
      • South Africa
      i got my hands on a secoundhand set and stripped them and outa the two i am still short
      The jet is No 40 and 1 short i can get from the agents
      still short two jet needle is marked SG1Z30 (slide needles)(452-14116-30)
      one emulsion tube marked 323 (5k7-14941-02)
      the latter two are now discontinued by the agents
      know ant other carbs i can strip perhaps
      • mro
        • 4276
        • Hayward, California
        81 RH
        Is like our special.
        81 SH
        BS34 III carbs.
        Rubber tipped float needles
        stock jetting
        110 main
        pilot 42.5
        main air 140
        pilot air 185
        set float height at 23mm
        manual shows using clear tubes attached to the float bowl drains to check fuel/float height. A hassel to do if not set up for it.
        mro
