Replace gears vs. grind dogs/slots
    • 5061
    ABSOLUTELY, Ken!
    • Jerry
      XS & TRUE XJ GURU
      • 3023
      • Elma, IA.
      I had posted this in a different thread, but thought it might also be applicable here:
      A variation is to have a machine shop cut a relief in the side of the 2nd gear that faces the clip the same size/thickness as the washer, then add a 2nd washer to the mix...you end up with a washer on each side of the gear. This way the 2nd gear does not ride against the clip, which is a concern for some people. Problem is the washer is discontinued from Yamaha, so you have to find one out of a junked tranny or find another one that fits.
      Anyway, you still end up with 2nd / 5th gear closer together but the 2nd gear can't rub the clip. When I had the work done on my gear the cost was about $25.00. I had a junked tranny that was the source for the washer. I took the washer to the shop so they could get the dimensions of the 'pocket' correct. Here is a photo of the cut gear:
      Only a few people have done this 'extra' fix, but I thought I would pass it along for anyone interested
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
