XJ Rear Brake Piston
  • shutchis
    • Oct 2004
    • 191
    • Deer Park, TX
    I need a rear brake caliper piston for an '82 XJ1100; anyone know where I can find one? My bike's piston has some serious damage on the leading edge touching the brake pad; I'm guessing the PO let the brake pads "fall off"; grinding itself to death on the rotor.
    If I can't find a replacement, I'll have a machine shop flatten the edge and install a shim; a new piston would be better. Thanks.
    '80 XS1100LG Midnight Special
    Looks like an '82 Maxim, Fuel Injected
    '82 XJ1100J, Fuel Injected
    Stan Hutchison
    Stan, I think they are the same as on the front and rear of the '78-'80 standard. If so, it should be available. You can use the Yamaha online parts book to verify the numbers are the same. If the numbers cross to a newer one, it USUALLY shows, but NOT all the time. Check with a dealer once you have the part number, and see what it may have changed to.
    • DELL82
      • 260
      • Houston, Texas
      Stan depending on how much is ground at an angle I can machine(face off) the bad part. Don't know how much is to much though. What is the travel on the piston? From new pad to worn pad is a guesstimate.
      Dell82
      Dell82
      Houston, TX
      82' XJ1100J Maxim "LASERMAX"
      SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
      SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
      SOLD 82' CB450SC Nighthawk, parts bike SOLD
