anybody got any ideas about what i can do for a rear brake resivoir? i am going to use an xs mc for the front and i think the rear one is shot anyway so i can switch it out to a single but i am not sure what to choose to switch it out with??? hmm
rear brake xj.
rear brake xj.
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairingTags: None -
Re: rear brake xj.
Originally posted by yamahansolo
anybody got any ideas about what i can do for a rear brake resivoir? i am going to use an xs mc for the front and i think the rear one is shot anyway so i can switch it out to a single but i am not sure what to choose to switch it out with??? hmmPaul
1983 XJ1100 Maxim
1979 XS1100 Standard
1980 XS1100 Special
I'm not a motorcycle mechanic but I play one on the internet.Comment
The XJ back brake runs the back and front left brake if hooked up properly. My plans are to run both front ones with one M/C, so I disconnected the line that goes to the front and plugged M/C with a teflon tape wrapped bolt.
There is a proportion valve in these master cylinders that adjusts the amount of pressure going to the rear and front depending on how hard you step on the brake pedal.... more going to the front under heavy braking. I didn't want a 26 year old valve deciding how much front brake pressure to apply when I really wanted back brake at the time?
Short story long... this setup I have isn't ideal. I don't have great back brakes, and the valve is still attempting to operate under heavy braking, so stepping harder on the brake doesn't have any appreciable effect. I couldn't lock up the rear tire if I tried on dry pavement. So.... this is new knowledge for me also to learn an XS M/C will bolt right up. I will probably go that route.
Working fine
Sounds like that 27 yr old valve is working just fine. Why is it you think it won't work if it's hooked up?You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
I'm pretty sure that it would work as designed... I just don't care for how it's designed! lol. I have many many more years on dirt bikes than I have on street bikes. Each brake effects the handling in a different way. When I want the front brake, I'll use it. When I want the back, I'll use that... not have some valve deciding for me. Just a personal conviction that I can apply both brakes in the oppropriate manner needed like on most bikes. Control freak? Maybe... but that's the name of the game on a bike.
Just one person's opinion... and you know what they say about opinions.
When I got rid of the unified braking on my XJ, I took out the insides of the proportioning valve and plugged the outlet going to the front caliper. I now have a great but not overly sensitive rear brake.
Louis"There is no mechanical problem so difficult that it cannot be overcome by
brute strength and ignorance" And possibly some Mouse Milk!
'82 XJ1100J
LED Dir and running lights
LED Tail/Brake lights (4) one flashing
Modulated H/L
PIAA Driving lights
YICS Eliminated
750 FD
Yamaha Factory X-1 Fairing and LuggageComment
my valve is shot and now it looks like the calipers are froze hard! i have a really big vice at work and i couldn't even get it loose with that!" She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
led's gallore...
renthal bars
vmax tensioner
Rifle fairingComment
