So I was troubleshooting a weak charging system this evening and I was going to perform some checks on the voltage regulator when I found what seems to be a wire missing from the 3-pin connector coming off the regulator (regulator side of the connection). I've posted some photos here so you can have a look at what I'm talking about.
Is this normal? I suspect not... but the regulator doesn't appear to have any other leads coming out of it that would go to this connector... so what gives? Would this be the cause of a weak charging system?
-Patrick
-Patrick
