U joint
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    U joint
    What is the easiest way to change the U joint? Really would not want to take out the engine, just got it in there. I wanted to change the u-joint then, but didn't have one. I'm thinking I can drop the swing arm lots easier than the engine.....
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
  • randy
    • Dec 2003
    • 4521
    You don't have to drop the swingarm, but you will have to pull the final drive to release the u-joint from the drive shaft. the u-joint boot is a hassle, but with a little patience it's not a hard job.
    There's a snap ring holding the u-joint onto the drive shaft. Book says to use a slide hammer to pull the drive shaft off of the joint. Yeah, like everyone has one of those! Slip a drift through the joint and a few taps gets it loose.
    • planedick
      • Mar 2005
      • 2068
      Did that
      I've had the final off and the boot off and all that, but it will not come out between the middle drive and the housing. I discovered it was dry and needed taken apart and greased, but we had just finished getting the engine installed and just couldn't find a way to get it out without removing at least the middle drive unit or the swing arm. Maybe the middle drive take out is the way to go?
      There's no snap ring on it as I've already done the final mod.
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
        Taking the middle drive out would be easier, but if you are worried about messing up the gasket and draining the oil, you can also take out the motor mounts and jack the back end of the motor up high enough to get it out (After loosening the 4 bolts in the U-joint 1st) I just installed a new rubber boot this way because I forgot about it until I droppped the engine back in the frame already.
        • planedick
          • Mar 2005
          • 2068
          Tried that too
          Before putting the back and front bottom mount bolts in I tried that and still couldn't get that darn thing out. I don't think the gasket is a problem as I have a dealer near here with all the gaskets and anything else still available ready on the shelf. I probably will remove the middle drive to do it, lots easier than the swing arm which means bags off, wheel off, final off, brake off etc, too much wrenchin that route.
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
            I was able to jack up the rear left side up high enough to get my boot and u-joint IN that I had greased and left out, but I don't have an airbox or anything there and may have more room than you to work with. It cocked the whole engine a bit sideways in the frame... made me cringe since I had just painted it.
            The middle drive option seems pretty easy though. Just remember to drain it first... it was time to change it anyway, right?
            If you've never had it off... it's the 7 bolts listed with white arrows. The bolt shown missing goes to the grounding strap.
            • exquized1
              • Oct 2006
              • 644
              • Polo Il.
              Brent changed his front ujoint in my yard in under an hour with just bare tools. Have a few pics in the nothwest Il. rallies. didn't look too hard. He was up and running in time for our ride.
              68 Honda Cl350 (sold)
              76 Honda Cb 400 super sport
              79 special (skull bike)
              79 special (parts bike w/title)
              79 special
              80 standard full dress (Sat 24 years)
              81 special (parts for now trying to get the title)
              81 kaw 750 ltd (sold to brother-in-law)
              80 650 maxim (fixing for wife)
              81 650 maxim
              81 Xs 650 special ( No title found in a barn)
              88 Zx 600r (Sold)
              01 Gz 250
