Hi All...
New to the Forum, Great Site... Lot's of good info.!
During a recent winter project to rebuild the carbs on my 79 Special, I noticed an interesting scenerio with the slides.
The small angled vent hole in the bottom of each slide is positioned at a differnet angle in relation to the airflow... Each carb is slightly different.
After doing a bit of close inspection and light cleaning of the slides and diaphragms, I noticed that each one of the slides can turn inside the rubber diaphragm. Since the orintation of the slide is not "locked" into, the slide would be able to turn inside the carburator bore.
In pondering that fact a bit... it seams that there could be slight variations in pressure/vacuum caused by airflow passing over the vent.... which could cause each carb to run rich or lean...
Here is my question to all the gurus...
What is the correct orientation of the angled vent hole in relation to airflow through the carb?
Thanks...
79Special
Thanks...
79Special
