My XS11 '79 Standard seems to have trouble using it's centrifugal timing advance. After a warmup the engine will idle clean and run up over 1,500 rpm with some throttle massage - prodding.
Under load, moving in 1st gear, it doesn't want to pull rpms cleanly but its NOT misfiring at all. If I come to a stop and wing it to 3,500 rpm it will take off and accelarate through the gears as normal with good clean combustion.
I suspect the timing advance weights are hung up or gummed. I need some tech tips "how to" get into and remove the advance mechanism since the factory manual has no real info or photos. Since the engine rotates CLOCKWISE, which way does the center plate's allen bolt turn out? I would rather not break the center bolt by going the wrong way.
Does anyone have pics of the inner advance plate mechansim being disassembled and serviced?
Any assistance would be much appreciated.
Rob
Rob
