Polishing
  • Polishing
    What do you guys uses to make the old cases look better? Thanks. I put a 18,000 BTU heater in my shop and am ready to get use of it.
    Bithdays are good for you: the more you have the longer you live.
    Caswell
    Caswellplating.com has really nice polishing kit with lots of different buffs and rouge, plus some liquid stuff like mothers all in a little kit. I got one and love it. Makes aluminum look like chrome.
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
      Most people just use sandpaper. Start course and end up fine. I start at @ 600 grit usually and used to end up at 2000, but there's a guy on Ebay that you can get 3000 grit from.... so that's what I finish with, followed by some Simichrome polish or Mothers on stuff that isn't going to get hot.
        here's what i did turned out pretty good , but if you want perfect, wet sand and then polish with the whit,or red.
        polishing
        79 XS1100 modified standard
        straight pipe 4-2 exhaust
        Owned 83 Honda V65 Magna
        Owned 02 Vstar 650 classic
        owned 85 Honda Shadow VT 700C
          I'm fond of black paint. It does wonders for the looks of the bike, if properly applied.
          Geezer
            Hi Del,
            if you are getting into serious polishing mode, get a buffing wheel. And a book on how to use one. And a breathing mask.
            Everything else takes longer and is harder work. Admittedly I have very low standards but since converting one side of my 8" bench grinder to run a buffing wheel I have routinely polished stuff that I would otherwise have just put back on "as is" or done a Geezer on and painted black. Paint has to dry, polishing is instant.
              Polishing ideas, and thanks
              Thanks to all.
