Headlight angle
  • Dennyz
    • 1151
    • Olympia, Washington
    Headlight angle
    Now that I have a very bright headlight, I wonder what the spec (if there is one) of the headlight angle?
    With my stock H4, I had raised the head light to provide the most headlight range. After the H.I.D. conversion, it was obviously too high. I put an incline meter on the face of my headlight and found it was 4 degrees above horizontal.
    I adjusted it down to horizontal and went back out. It seems much better, but I did not pass any cages to see if they "high beamed" me. On low beam the H.I.D. has a very distinct horizontal line of light. Above it is dark, below it is light.
    It is probably a trial and error process, but thought I would inquire.
    DZ
    Vyger, 'F'
    "The Special", 'SF'
    '08 FJR1300
  • petejw
    • 2269
    • sydney australia
    Hi Denny,
    When we used to check for headlight alignment,
    for both cars and bikes,
    find urself a level area,
    ull want a wall or something similiar to shine the headlight onto,
    park the vehicle about 25 feet away from the wall,
    headlight on high beam,
    adjust the headlight so the beam on the wall is the same height as the headlight on the bike/vehicle.
    hope it makes sense.]
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • Dennyz
      • 1151
      I will give this a try and see what angle the headlight ends up.
      DZ
      Vyger, 'F'
      "The Special", 'SF'
      '08 FJR1300
        I use the "drive by sight" method. Adjust the LOW beam so it is just below the top of the trunk lid ( boot for the other side of the pond). That should keep the cars happy, and you will have a good view of the road.
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          Check this out
          http://www.gadgetjq.com/aimheadlight.htm
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
