Separation anxiety
  • Incubus
    • 1003
    • Austin TX
    Separation anxiety
    I will readily admit she frustrated me. This wicked machine. This taunting temptress. Flashing me. Tantalizing me. Then not firing at idle on number 1 just to frustrate me.
    We had to take some time apart. Well, I had to anyway. It's not like I didn't have several bikes to ride (all of which idle). And ride I did. I put more than 6,000 miles on two wheels this summer. It's not like I didn't have several other projects. It's not like....
    The b****. She's an evil siren, luring my ego to the rocks.
    So Succubus sat while I restored a 1969 Honda CB 750 for my son to ride. Then I kept the '69 and gave him the '75 Honda 750. All the while Succubus sat parked in my garage, watching. I hoped she was lonely. I hoped she was jealous. I hoped she was learning her lesson.
    This morning, just for grins, I figured I would hit the starter button so she could make fun of me some more. I hadn't charged the battery since July, so I figured at best she would give me a low moan while she pretended she wanted to start.
    Boom. She fired right up. The taunting starts anew.
    Gotta put a charge on the battery and go in search of the missing idle. This time she is going to turn into an everyday ride. At least in theory.
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
    Hey Patrick
    Good to see you back. Was wondering were you went. Good luck with the bike and keep us posted.
      Patrick,
      Check the wires to the front pick-up coil.....DAMHIK
      • planedick
        • Mar 2005
        • 2068
        • Yorba Linda, California
        DAMHIK
        Calling us country boys names now are we?
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        Custom security system
        Stainless braid brake lines
          Don't Ask Me How I Know...... I tried to tell Yamaha about a problem early in 1978 when my first XS1100 was dropping #1&4 at idle. That is when I found the crimp that holds the pickup coil wires was too tight, and would break the wires.
          • Incubus
            • 1003
            • Austin TX
            I wish it was the pickup coils, Ray. I kept going back to them the last time. I've soldered and resoldered, replaced, soldered and resoldered the new ones etc.
            This time around I am concentrating on the potential of an air leak. It always kicked ass once I got it moving......
            Patrick
            1969 Yamaha DT1B
              Try one more time on the wires. Put a VOM on one end, with the "beep"on, and go to the wires and pull from different angles on the front coil. It will be the front coil, and you may find that at idle, when you have the MOST vacuum, is when the wires will just pull to an open. It was HARD for me to find it the first time, and my bike now is giving me problems once again. I think this time it has something to do with the 95K miles on it, as well as at least two "fixes" on the coil wires to the front.
              • Incubus
                • 1003
                • Austin TX
                I think I'm going to approach this like I've never seen the bike before. I know I can find the problem. I am convinced I was blind to it last time because I did something that I was sure was right, so I therefore could not consider it the diagnosis.
                I know it will start - much more easily than I expected, in fact. I put in some fresh gas, opened the petcocks and the badly drained battery could manage only one "oomph." But that was enough. It caught. Shocked the hell out of me.
                Maybe it healed during the layoff. So tomorrow, after the battery charges, I'll start it and see if it idles on no. 1. If not, I'll pull the plug wire and see if I have fire at idle. If I have fire, I'll start looking at vacuum.
                It's winter in Texas - riding season.
                Patrick
                1969 Yamaha DT1B
                • webbcraft2150
                  • Sep 2002
                  • 1605
                  • AUSTIN.TX
                  Patrick [/B]
                  Yeah, right. December 7th, 78+. You will hear no complaints from me. Hmmmmm, boats in the drive way, maybe I should go burn the last of the "summer" gas out of it. Darn, almost a full tank, could take better part of a day to burn that much fuel out, unless I go to "burn the carbon out" or do a "plug check". Yea, that it, to much carbon and I hafta check the jetting ( she will never snap its fuel injected!!!!! )
                  Glad to hear from ya, thought you had given up on the old girl.
                    Re: Separation anxiety
                    If it was me, I'd be looking for spooge in the wee orifice in the bottom of the float bowl on #1. If it is blocked, that carb will not run at idle, but as soon as you come up past that rpm range, it will come to life as the next stage comes on.
                      Just a thought... but have you checked the compression on that one cylinder? If it's low, then it could be getting enough when the RPM goes up and letting it fire. Probably not it, but worth a check?
                      • planedick
                        • Mar 2005
                        • 2068
                        Just thinking
                        Yeah, I know, that could be dangerous, but I agree with Ken, probably got something in the bowl idle jet. Really easy to take care of, don't even have to take off the carbs, just take off the bowl and check it.
                        Drilled airbox
                        Tkat fork brace
                        Hardly mufflers
                        late model carbs
                        Newer style fuses
                        Oil pressure guage
                        • Incubus
                          • 1003
                          • Austin TX
                          The compression is good, Tod. I'm leaning toward spark. I started a new thread to talk about it. Please see "Let's talk spark."
                          Patrick
                          1969 Yamaha DT1B
