oil cooler
  • floridajoe
    • Jul 2003
    • 94
    • pompano beach florida
    oil cooler
    on my 81 midnight i have a lockhart cooler.
    i cant find one like it for my 78s any body know were i can get one
    Joe Bjordahl
    “speed don't kill it’s the sudden stops”
    Yamaha xs1100 are addictive
    1979 XS1100S
    1981 XS1100 MIDNIGHT
    1982 XS1100S DONER BIKE
    Hey Joe,
    They're not made anymore for our machines, so folks try to find them on the BAY, ones for the 850 also fit.
    However, folks around here a while back wanted to have the ability to use a spin on oil filter with their cooler, but didn't want the 1" extra SOFA sticking out/down below their cooler plate, with the filter below it loosing ground clearance, and so with some help, I came up with an adapter for both the cooling and the spin on filter. See this tech tip for details. I don't have any currently in stock, sold the last batch a few months ago, but haven't had much demand for them, but now that winter is upon us, I'll be getting back out into the garage to process some more.
    You'll still need to get a cooler to connect to the adapter plate. I've done some online searches for them as well, seems like the Trans coolers are the ones to use, cause they use the 3/8" clamp on hose connectors which is what will fit onto the SOFCA!
    Maximan always goes over the top with his bike/mods , but he informed me that where it attaches to the cooler plate is just compression/push on clamped hose fittings, not those fancy AN style seen at the thermostat!
    Below is the text and info I had found, meant to add it to the above tech tip, just kinda forgot!
    Maximan said:
    Of course I am running a "customized" rig. I have a B&M plate style cooler. The exchange rate of this type cooler is supposedly superior to a fin/tube type.
    Here's mine:
    It's a B&M SuperCooler in polished aluminum. It's a plate style obviously instead of the old fin and tube style.
    You can get them from most any autoparts store. I got mine at NAPA. I think it was about 75 or 100 bux.
    The thermostat is B&M too. Opens at 180 degree. The SS tubing that connects the thermostat to the cooler I made myself.
    B&M Import Cooler #70261
    Thermostat valve 70259
    Fluidyne smallest
    10-Row Plate-Fin Oil Cooler 11 X 4 X 2 0.25qrt/cap fit:AN-8 $96.00
    PWR brand 38mm thick
    5-Row Plate-Fin Oil Cooler 11.25 X 4.5 X 1.5 .16qrt/cap fit:AN-10 $59.00
    Northern
    Remote Engine Oil Thermostat 3 1/4 X 2 1/2 1/2" NPT $53.18
    Northern Cooler parts from
    Transmission Oil Cooler Kit for Compact Cars & Light Trucks
    Z718026 $76.50
    Derale brand Trans Cooler FinPlate design on
    Series 8000 Tube & Plate Cooler Kits
    • Designed for late model electronic overdrive transmissions
    • 3/4” wide embossed turbulator plates minimize pressure drop
    • Sturdy furnace brazed aluminum construction
    • Complete mounting and installation kit including nylon & metal mounts
    • High impact color skin board packaging
    Series 8000, 3/8" push on fittings,
    13501 GVW15500 11"x6"x3/4"
    Thermostat:#13011 Transmission Applications 3/8” NPT x 3/8” Hose Barbs
    180° Fluid Control Thermostat
    • Bypasses the cooler until the temperature reaches 180°F
    • Provides faster warm-up to operating temperature
    found at:
    Explore JC Whitney for premium auto parts & accessories, dive into car culture, & stay updated with the latest automotive events & tech trends
    www.summitracing.com Good Prices B&M coolers!
    • floridajoe
      • Jul 2003
      • 94
      cool thanks
      Joe Bjordahl
      1979 XS1100S
