Calling all carb swap gurus!!
  • #16
    Originally posted by audijunky
    Allright, that is good news
    The seller said they were off a 93 GSXR 1100.
    They look exactly like the GSXR1100 Carbs used from 1993-98.
    1980 XS11 Basketcase
    • #17
      Did some mods to the carbs to get them to fit. Just typed this big long story and my fing computer screwed up and it got lost. I'll try to post some pics tomorrow with some descriptions. bUT i GOT THEM TO FIT.
      79 XS1100 modified standard
      straight pipe 4-2 exhaust
      Owned 83 Honda V65 Magna
      Owned 02 Vstar 650 classic
      owned 85 Honda Shadow VT 700C
      • #18
        How 'bout typing that big long story again - including the pictures?
        Ben
        1985 Yamaha VMX12n "Max X" - Stock
        Formerly:
        1982 XS650
        1980 XS1100g
        1979 XS1100sf
        1978 XS1100e donor
        • #19
          heres some parts from different forums I've posted in.
          So I founed a cheap set of 93 GSXR 1100 carbs on ebay and bought them. Apparently the 750's have slightly different spacing. and mine were to spread out (carbs 1+4) to fit my head carb boots. SOOOO I took them apart from each other and modded the nut side of the butterfly shaft on carbs 2+3 to allow 1+4 to move closer in. I also had to belt sand down the fuel and air nipples on carbs 4+2. To allow the back side(air inlet side) of the carbs to move in closer. All of this brought carbs 1+4 about 1/4 inch in and now they fit with a little encouragement. Well, when I was putting the nut back on the butterfly shaft of carb 2 (which has had the lock washer removed to allow for space) I tightend it down to much putting pressure against the butterfly(actually pushing it against the carb throat) and it bent. Figured at the time it would be an easy part to replace so it got kind of beat up when trying to pull it back through the butterfly shaft. And that my friend is why I am looking for one. TADA that wasn't as long as I thought it was going to be
          • #20
            Still have to connect the vacuum advance, throttle cable, and choke lever(which is going to have to be modified). But they fit and the throttle plates operate smoothly. I bent one of the throttle plates(explained in the above post). Gonna have to replace it or try to fix the one I have. Figured they would be easy to buy seperate but they are not.
            Some clown on another forum said he found one and it would be 48.00 shipped!!!! Please I might beable to get a set of carbs for that price. Any way I'll get some pics this weekend and postem up Monday mornin.
            Any questions till then feel free>>
            • #21
              Well I painted on some pics to show where I made mods, and here they are. Lines aren't exact locations just trying to give you an idea. I also had to drill new holes in the connecting rails for carbs 1+4. 2+3 are close enough to the xs placement to fit.
              • #22
                Got some pidcs of my modded carbs from the 93 GSXR 1100. here they are
                If you compare the before pics you can see the difference
                • #23
                  Allrighty then here they are
                  • #24
                    Have you got these bad boys tuned and working, yet?
                    Formerly:
                    1982 XS650
                    1980 XS1100g
                    1979 XS1100sf
                    1978 XS1100e donor
                    • #25
                      haven't had a chance yet. waiting on my new dual throttle tube and mount to show up. I have mounted them, and hopefully will get a chance this weekend to sort them out. Ill get some more pics too. Later
                      • #26
                        Trying to Sell 2 sets 36mm Keihin CVK. Take a Look.
